1969 Dodge Dart GT freshen up
You got that right. trying to just do what's necessary.
..................stroker...................
Small Block bolt sizes
oil pan
5/16"{18}x 3/4" amount needed 18
valve covers
1/4"{20}x3/4" amount needed 10
fuel pump
3/8"{16}x1 1/2" amount needed 2
thermostat housing
3/8"{16}x1" amount needed 2
intake manilofld
3/8"{16}x1 1/2" amount needed 12
was looking for water pump bolt lengths. Found this on mopars. Figured I'd share it.
water pump & timming cover as a combo-set
3/8"{16}x5" amount needed 4
3/8"{16}x3 3/4" amount needed 3
3/8"{16}x1" amount needed 3
3/8"{16}x2" amount needed 1
distibuter hold down
5/16{18}x 3/4" amount needed 1
Looking into ditching the spacer between the intake and thermostat housing. The only reason i have it is my temp switch is too big and I didn't have a port left in the intake that was big enough.
This one has mixed reviews. Not sure why it has two spades.
Because it is a temperature switch for controlling a fan, not a temp sender for a temp gauge. Which are you seeking, and if you are wanting a temp sender for you gauge, is it the stock temp gague?
Nope I worded it wrong I am looking for a switch to control my fan.
Figure while I'm at it mine as well get the correct heater hose fittings for my air gap.
http://m.ebay.com/itm/MOPAR-1970-78...Fittings-70-71-72-73-/231744732690?nav=SEARCH
If I used a fitting like this. I could reuse the switch I have now. It might put he heater hose higher. Unless I put the switch on top and the heater hose out the side.
5/16" OD = 1/16 NPT
3/8" OD = 1/8 NPT
1/2" OD = 1/4 NPT
5/8" OD = 3/8 NPT
3/4" OD = 1/2 NPT
1" OD = 3/4 NPT
1 3/8" OD = 1 NPT
Ya know, you could get an all female tee with a male-to-male nipple with one end in the bottom of the tee and the other end of the nipple downward into the manifold, and then have the sensor face out the front side opposite the hose connection and it might be out of the hoses.
Scat I beam Rods are on order. Going to use my h116 pistons I had laying around. Bringing block to machine shop Monday to have the cam bearings installed, cylinders rabbit turded, parts externally balanced.
Out with the 405's
