[FOR SALE] 1969 Olds Cutlass S Convertible
frumharlem
Active Member
Indiana
Rating - 0%
0   0   0
Specs:
350 Rocket Motor
2 Barrel Carb
Auto Trans Column Shift
Factory A/C
Non-Locking Rear
Good:
Very reliable and decent condition driver
Re-sprayed and wet sanded smooth finish & shine
New Top and Rail Seals
New Carb
New Battery
4 new tires
Full tune up May 2013
Clean trunk
All trim is there and in place
solid trunk and floors no patches
Bad:
The top motor is "sometimey" and either needs to be rebuilt, line bled, or fluid added
There is a 3 inch crack in paint on hood and small scratches/cracks at nose of hood (see pics)
The power steering pump squeals at start up and revs, after about 10 minutes driving it goes away and only squeal if you rev the engine hard in Neutral or park to like 5000 rpm
There is a small bubble coming through paint at the very bottom corner of the rocker after door
Needs new carpet
MORE PHOTOS HERE : http://www.use.com/69_CUTLASS_c7cb3f4afa17e5ee9d3f
$9,900
Honestly, I never checked. Any other color would look horrible (Black or White :( )
I have a picture of the build sheet I can send you, but I did not try and pry it from under the seat springs, for fear it would crumble.
Good luck with the sell
Good looking car, always liked the late 60 early 70 cutlass convertible
Looks like it is on northwest side of INDY
Specs:
350 Rocket Motor
2 Barrel Carb
Factory A/C
Non-Locking Rear
Good:
New Carb
New Battery
4 new tires
Clean trunk
Bad:
Needs new carpet
$9,900
AUGUST 18, 2013
SQUEAL FIXED, it was a belt adjustment. Installed new Alternator this weekend.
Sigh...'69 442 is the only non-Mopar I've lusted after.
I went to school with a guy had a 69 442. 400, 4 speed. Dark green. Total sleeper. Bone stone stock. That car would lay rubber for 2/3 of a mile. Both tires. Nice car. GLWS
