1969 Valiant Hood?
Mopar Body and Trim
  1. 69val
    69val 1969 Valiant Gasser
    13
    0
    Mar 25, 2016
    Sophia, Wv
    Local Time:
    7:03 PM
    I have a '69 Valiant that is an old Gasser build. I am putting it back on the road but need an Hood. I'm putting a 413 W/ Tunnel ram and don't want to cut an hole in the Fiberglass Cuda' pro stock hood. I have checked in a few sited and I didn't find out that it is a correct fit. Sooo I need a metal hood and can't find one anywhere. Is there another A-Body hood that I can hunt out?
  2. Sedanman
    Sedanman 67-9 Valiant specialist
    8,508
    614
    Apr 3, 2009
    chicago Il
    Local Time:
    6:03 PM
    70 to 72 duster
    • Thanks! Thanks! x 1
    • 69val
      13
      0
      Mar 25, 2016
      Sophia, Wv
      Local Time:
      7:03 PM
      Why did the Cuda' hood fit? Is it not supposed ?
    • DNasty777
      DNasty777 Perpetually In Pieces
      755
      260
      Jul 18, 2011
      Rochester, NY
      Local Time:
      7:03 PM
      As Sedanman said 70-72 dusters have the exact same hood as the 69 Val. IIRC all 67-76 hoods will "fit", as in bolt up, but the later hoods have the adjustment in the hinge and the earlier ones have sliders in the hood itself. Soooo, the cuda hood will bolt up but the bump in the center of the hood doesn't match the 69 Vals', although i believe Cuda hoods are basically the same profile as the dart sport.
      • 69val
        13
        0
        Mar 25, 2016
        Sophia, Wv
        Local Time:
        7:03 PM
      • 69val
        13
        0
        Mar 25, 2016
        Sophia, Wv
        Local Time:
        7:03 PM
        What is IIRC ? All as in the A-Bodies ?
      • 69val
        13
        0
        Mar 25, 2016
        Sophia, Wv
        Local Time:
        7:03 PM
        Thanks Stedanman for your input
      • Dartnut
        Dartnut Don't hate me because i'm beautiful
        11,889
        5048
        Apr 19, 2007
        Southern Alberta
        Local Time:
        5:03 PM
        You can get a fiberglass hood for a '70 to '72 Duster/Valiant 4 door/Scamp for pretty cheap. (Or a regular steel one if that's what you really want). All '69 Valiants had the same hood as well.
        A 'Cuda hood ('67 to '69) would physically bolt up to the hinges, but it is all wrong on the front and would look bizarre.
        How about some pictures of what you have now?
        • 69val
          13
          0
          Mar 25, 2016
          Sophia, Wv
          Local Time:
          7:03 PM
        • DNasty777
          755
          260
          Jul 18, 2011
          Rochester, NY
          Local Time:
          7:03 PM
          IIRC is internet slang for "If I Recall Correctly". All A-bodies 67-76. But as Dartnut said it would look wrong.
          • 69val
            13
            0
            Mar 25, 2016
            Sophia, Wv
            Local Time:
            7:03 PM
            [​IMG] [​IMG] [​IMG]
          • 69val
            13
            0
            Mar 25, 2016
            Sophia, Wv
            Local Time:
            7:03 PM
            I have tried to post pics but can't seem to make it happen. I see IMG come up but... Anyway I only have 3 pics of the car before I have started work on it. I will try again when I figure out the correct way to put them on here. Thanks you guys for your help for now though...The pics show that the thing is sitting very low in the front. As of now it is up pretty much with the back.
          • Dartnut
            11,889
            5048
            Apr 19, 2007
            Southern Alberta
            Local Time:
            5:03 PM
            This is what a hood should look like on a '69 Valiant and a '69 'Cuda (red car).
            Yes, they're both mine...........
            • Like Like x 1
            • 69val
              13
              0
              Mar 25, 2016
              Sophia, Wv
              Local Time:
              7:03 PM
            • 69val
              13
              0
              Mar 25, 2016
              Sophia, Wv
              Local Time:
              7:03 PM
              These are the car when I first got it. Not the same now. The work I have done as of now are not on the cosmetic appearance. Different, Rear end. 8.8 373, Front axle has brought the front level with the rear. Tilt front clip, The Cuda' hood is what I don't want to cut a hole in...just need a plain hood. If you have an Jobber that has what I need, please tell me. Thanks all you guys!!!!
            • Dartnut
              11,889
              5048
              Apr 19, 2007
              Southern Alberta
              Local Time:
              5:03 PM
              That's not a 'Cuda hood, it's a Valiant/Duster hood.
              If you are talking about the scoop, then it's similar to a '68 Hemi Super Stock or Dart scoop.
              Go get yourself a steel hood and cut a hole in it if you want, there are lots of them around and are pretty common really.....
              • 69val
                13
                0
                Mar 25, 2016
                Sophia, Wv
                Local Time:
                7:03 PM
                There is a sticker on the underside that says Cuda'.
              • 69val
                13
                0
                Mar 25, 2016
                Sophia, Wv
                Local Time:
                7:03 PM
                Ok, I have taken a pic of the sticker and it has the Pentagram ?? Chrysler sign? and it says AAR on it with the phone # and address!!! But after checking with the real!! info it is made by Quality Fiberglass Reproduction. After looking up that Co. I find the AAR doesn't mean so much. It is likely that it isn't what it appears to be. I believe it is just what they want to label it by and not actually a Cuda' hood. So I have to agree with you! Thanks for your info! I have the front clip off and it is on my lift so there isn't much of a car to show you. I'm putting the motor in it now. Someone had a BBC motor in it and I've had to make a new location bracket for this 413. I'm green when it comes to rebuilding a Gasser. Thanks again for your input !!!
              • Dartnut
                11,889
                5048
                Apr 19, 2007
                Southern Alberta
                Local Time:
                5:03 PM
                • Like Like x 1
