[FOR SALE] 1970 and later SB timing cover
SGBARRACUDA
ROY
Legendary Member
PLANT CITY FL.
Timing cover is Mopar part number 3769966, Date code is 1982. Will work on all small blocks after 1970. This cover uses the crank seal that installs from the front. Makes future seal changing easier because you don't have to remove the timing cover to replace it. Cover was media blasted, inspected for any damage and all the threaded holes are cleaned with a tap. I then paint them with the correct color engine paint. $60.00 shipping included in the USA.
