New hubs were never sold separately by anyone. The dealer sold them as a hub and drum assembly, but, long since discontinued. Find a used one. Just make sure to check the tightness of the bearing races. It's very common for the outer race to have spun in the hub. Once it does that, they're pretty much junk unless you want to spend a fortune to weld them up and machined back to the proper specs. The hub and drum assembly from 1960-1972 will fit even though some years may look a bit different. Some '70 models, and the '71-2 9" drums were finned, whereas the earlier ones were smooth. They'll both work though, but, I would use a matched pair, as, they will fade at a different rate when hot and might cause the brakes to pull to one side.
