1970 Dart Kelsey Hayes Disc brake upgrade and 14x4.5" SBP wheel caliper clearance
DaisyDart
Quebec
I have a 1970 Dodge Dart 225 Slant-6 with 14x4.5" small bolt circle wheels and 9" front drum brakes. I am considering a Kelsey Hayes style oem disc brake upgrade from the company SSBC but am worried that the 14x4.5" small bolt circle steel wheels may or may not clear the calipers. I have measured my wheels narrowest internal diameter to be 12" just. According to the technical data provided by SSBC they indicated a total diameter for the brakes to be 11.36" (5.68" Radius x2) and if compared to the narrowest area of the wheel it makes a close fit but "technically" possible.
The kit I am looking at is for a 1969 Plymouth Baracuda part #W153 using 10" brake spindles which I would also need to do the disc upgrade. In the application listing it states that it fits with 14" wheels but does not specify if they mean Rallye wheels or Black Steel wheels like what I have. If they consider the 10" brakes to be V8 spindles I worry they assume you will be using Rallye wheels. While doing research about this topic I came across a review for this application on Summit Racing which read as follows and confirms my concerns even though the technical data seems to show that the brakes will clear without interference with the wheel: My question is has anyone successfully done this upgrade to their A-body using the 14x4.5" steel wheels?
DISC BRAKE KIT - FRONT - 4 PISTON - 11 INCH ROTORS - V8 SPINDLE - W153
"SSBC Ad for this kit misleading about 14" wheels !"
Summit Racing Verified Purchase
SSB-W153
Apparently the only 14" factory steel wheels that clear calipers are the the Mopar Rally's, all other factory black 14" steel wheels rub/interfere with outboard side of calipers (unless widened).Instructions don't specify caliper install with bleeder up, had to use undersize axle nut cotterpin or drill out axle shaft to bigger diameter hole. All in all seemed good quality kit, but they should modify their wheel fitment statement to clarify, because their cross sectional diagram is not very helpful when most wheel manufacturers don't publish the dimensions of inside of bolt flange to area where caliber rubs only offset and backspace! "
https://www.summitracing.com/int/parts/ssb-w153/overview/year/1969/make/plymouth/model/barracuda
Link to SSBC directly: Disc Brake Kit - Front - 4 Piston - At the Wheels only - 11 inch rotors - V8 Spindle - W153
From my calculation .. you will be upgrading to 15 inch wheels ( big bolt pattern ). Do yourself a favor .. if you want to stick with SBP.. locate KH original disc brake system
The calipers are available from Classic industries, but which rotor and spindle would you use if bought separately? The idea here is to retain the factory upper control arms and small bolt circle and small wheels.
IT IS going to cost you a lot of money if you piece everything together ... I have been there ... I have the complete setup ... all you need to do is bolt lower ball joint on to your lower control arm and replace your uppers to accept the KH setup ... 700 + delivery
use original K-H setup from any 340 64-72 A-body. spindle, caliper, shield and hub/rotor. any rim that came on a 340 A-body will fit either steelie or rallye. a used setup should be $300 , then call Rock Auto and get calipers and rotors. I saw rebuilt calipers for $125 each and replacement rotors for $100. If you are replacing your lower control arm/ strut rod bushings, upgrade to 340 LCA with sway bar tabs and add the sway bar. I am in Hartford, CT and could put a setup together for you but shipping is very expensive
