[FOR SALE] 1970 Dart with 5.7 Hemi swap
jrlegacy23
68 Barracuda
Laurens, NY
In the middle of a project that I have been losing interest in, and thinking about selling. It is my 1970 Dodge Dart, originally a southern 318 car, there are a couple bubbles of rust behind the drivers side tire and a small spot (1/4") on the drivers side floor pan (below gas pedal).
This car now has many, many extras now and in the middle of a 5.7 Hemi swap. I am sure I am missing something, but here is a list:
2006 5.7 Hemi from a Dodge Magnum (60 kmi)
2007 Ram 1500 545 RFE transmission (73 kmi)
Hotwire Auto full engine/trans harness with OBDII port and own fuse box
Hotwire Auto programmed factory computer
TCI Breakaway torque converter 2600-2800stall
Hemi Denny K-Frame with mustang II rack and pinion
QA1 Coilover conversion
1" front sway bar
2" Mustang drop spindles
11" - 4 wheel disc brakes - drilled and slotted rotors
Champion 3 row aluminum radiator
New AMD passengers side fender (old one was dented on the body line, still have it)
8.8 rear end, rebuilt with 4.10 gears and carbon fiber clutches around 100 miles ago
rear 5/8" sway bar
trans tunnel cut out and refabricated for the 5-45RFE trans
Comes with 3 gallons on Lizard skin sound deadener
65 mustang fuel tank mounted thru the trunk floor with an in tank electronic pump, all Nylon braided, steel infused, E85 safe lines ran from the tank to the engine
tank is designed to line up and work with the factor fuel fill door
Jeep SRT-8 shorty headers that clear all parts
3" down pipes with O2 bungs welded in
Spaghetti engineering digi-tails LED tail lights
Ridler 18x8 rear wheels, 17x7 fronts
Hotchkis rear autocross springs
DoctorDiff spring offset kit (3/4")
All Autometer white face gauges
welded in subframe connectors
I have the original column shift steering column and a 72 Duster column that is was floor shifted
Engine bay is painted PPG Viper Snakeskin Green
I am asking $14000, or best offer. Also will trade for a 2008 or newer Challenger, want a Hemi but will consider a V6 (beggers can't be choosers :) ).
May also consider a 2010 or newer Hemi Charger (but very picky on which Charger, as I really want a Challenger)
Located in Central NY and can deliver if needed
I took the car off the market for a little bit, I thought I was going to continue working on it. I worked on the car a little and it is now running and cooling system is done. The heater core is in, has a new relay box, still needs the interior finished, I am negotiable on the price. I have pretty much everything to finish it up. I am negotiable on the price
