[FOR SALE] 1970 Dodge Dart Custom
Mopar Automobiles For Sale
  1. wes beem
    wes beem Well-Known Member
    509
    201
    Apr 16, 2017
    ohio
    Local Time:
    8:10 PM
    Contact Seller
    Up for sale.
    ZANESVILLE OHIO
    Purists be warned.
    Keep Scrolling.
    1970 Dodge Dart running driving tire roasting semi restomod driver.
    The car WAS a factory /6 car.
    The car is now a warmed over 360 Magnum with low miles, Lunati cam, Edelbrock 4 bbl intake with a Holly 600 street warrior carburetor and Dougs long tube headers with dual Flowmaster 40 exhaust. MSD Ignition and Brand new full painless performance wiring harness from front to rear.
    Almost every single part on this car is brand new and was either purchased at Jegs, Summit Racing, or Advance auto. The only major parts that are not brand new or rebuilt with new parts are the K member, the rear leaf springs, rear end center section and axles.
    New fuel system, tank, lines, pump, carburetor ext.
    New Brake system, lines, front calipers, rear drums turned and rebuilt new, new master cylinder
    New cooling system radiator hoses trans cooler lines ext.
    New electric fan
    New driveshaft, New U Joints, fully rebuilt 727 transmission with less than 20 miles on it.
    New reverse manual valve body
    New B&M Quicksilver shifter
    New LED HALO Headlights
    New Intelitronix fully digital gauges (all work)
    New Wiper switches New headlight switches
    New front suspension, Qa1 control arms, new idler arm, pitman arm, inner and outer tie rods, new upper and lower ball joints, new shocks all around
    New steering column and steering wheel complete with 6 position tilt (VERY NICE)
    New Carpet, Newly wrapped headliner and sail panels, Newly wrapped door panels (front and back)
    Like new sun visors
    New Package tray
    New Kicker Speakers, New fully functional backup cam installed in a fabricated upholstered under dash console with speakers.
    New weather stripping everywhere
    Newly installed front and rear windshield, front is brand new.
    Holley Street warrior 600 carb is brand new
    The car runs drives and stops great.
    Steering,handling,and braking is better than when car rolled off the lot brand new in 1970.
    The warmed over 1998 360 Magnum motor will roast the tires and leave two burning trails of rubber on takeoff. Super Super fun car to drive and gets tons of attention on the street.
    The car as she sits is at about 90% completion.
    There are a few odds and ends that need finished on the interior such as a back seat or back seat delete panel. The trunk also needs carpeted.
    The car is as rust free is it gets with a brand new paint job.
    I will be fully honest here, the paint job is nothing to write home about. The color is "Green with Envy" and the painter got some metallic and pearl buildup here and there. Its good enough for a daily driver. The bodywork was all done RIGHT and I have full documentation and photos of everything under the paint. Rust along bottom of rear quarters was cut out and fresh patch panels welded in. Shes a pretty straight car but not a SHOW car. The underside of the car looks real good and doesn't have cancer eating it up.
    That's pretty much all there is to it. She is not a show car and if you just wanna come pick it apart then it is probably not the car for you. If you are looking for a balls to the wall super fun hotrod that your not afraid to do a little bit of work this winter to to make it Your style then its the car for you. I have over 22K and 3 years of 5-10 hour days and nights invested in making this car Mechanically and electrically sound and undoing all the typical shit that cobblers like to do to mess up these cars. I have over 300 progress pics from start to finish for any serious buyer.
    Price is 11K OBO
    Again, over 22K invested and almost every single part on this car is brand new.
    71819795_10211806814485780_4884169549823344640_n.jpg 72210330_10211806814205773_5403067406669053952_n.jpg 72758813_10211806813325751_4533481535914901504_n.jpg 72112663_10211806812765737_3799716575603326976_n.jpg 71956912_10211806811565707_4101643417778388992_n.jpg 73482695_10211806810605683_3129774614561947648_n.jpg 72352226_10211806810165672_1130668982693527552_n.jpg 72717459_10211806809605658_6606966904609308672_n.jpg
    • Like Like x 5
    • wes beem
      509
      201
      Apr 16, 2017
      ohio
      Local Time:
      8:10 PM
      • Like Like x 3
      • 1970boy
        1970boy Well-Known Member
        129
        21
        Jun 1, 2016
        California
        Local Time:
        5:10 PM
      • wes beem
        509
        201
        Apr 16, 2017
        ohio
        Local Time:
        8:10 PM
        ill have them Monday, I cant put the driver side door panel/arm rest assembly back together until my retaining clip for the remote mirror arrives from PG Classics tomorrow.
        • Like Like x 1
        • wes beem
          509
          201
          Apr 16, 2017
          ohio
          Local Time:
          8:10 PM
          Interior pics as promised.
          72406913_10211871517783322_7330097465766445056_n.jpg 72573243_10211871517543316_5166883723383144448_n.jpg 73458673_10211871517263309_8738431394042085376_n.jpg 72879371_10211871516783297_5014335070668849152_n.jpg 72781814_10211871516063279_7935190072087805952_n.jpg 72542417_10211871515783272_3421837548945670144_n.jpg
        • wes beem
          509
          201
          Apr 16, 2017
          ohio
          Local Time:
          8:10 PM
          Don't be shy guys, come give her a test drive and you will fall in love!
          How often do these A bodies pop up for sale with Brand new everything mechanical/electrical instead of pieced together with rotted rusted junkyard parts?
          Good solid A body here that's ready to run and drive. Come get her and put her up in the garage over winter, do some minor aesthetic TLC to get it to your preference and unleash the beast come spring!!!
          Open to reasonable offers.
