adamp
Well, I figured I'd give you guys an update on how my car is going... I spent some time cruising it, and decided it was time for paint. This was my first time doing paint by myself. It came out alright I think... I made the mistake of laying the tape stripes down first and forgot to paint the trunk jams. I will spray those and my hood when I get my hemi hood scoop in.
Hope you guys enjoy!
Paint and Color:
Custom Color I Had Made by Bobs Auto Paint Merced, Ca.
Pinch of Gold Flake
Painted In The Backyard
Body Mods:
Shaved Moldings
Shaved Roof Gutter Rails
Shaved Antenna
Shaved Side Marker Lights (Front and Rear)
LS6 Engine and Mods:
.030 Milled 243 Heads
Ported and Notched Throttle Body
Milled .030 243 Heads
232/234 Custom Grind Comp Cam
Trunion Upgrade (Comp Cam)
7.375 Chromoly Push Rods (Comp Cam)
LS7 Lifters
Double Spring Valve Springs
42lb Bosch Injectors
Nitrous Express Plate Kit With 10lb Nitrous Express Bottle
Tuned at Starkweather Performance and Tuning
4L60E Transmission:
Corvette Servo
Beast Sunshell
.500 Boost Valve
Racing Band
Shift Kit
Alto Red Clutches
(3-4 Clutches) Z-Pacl
High Rev Pump Spring
Hardened Pump Rings
Big Low Reverse Boost Valve
Still Left To Do:
Paint Dash Surround Black
Paint Grill and Install
Install Gauges and Dash
Paint All Trim and Mirrors Black
Paint Trunk Jams and Hood+Scoop
Get Wheels/Tires
Finish Interior
Install Weatherstipping and Final Trim Pieces
Go Turbo (I Have Heads/Wastegate/Blow Off Valve)
Images:
Truly a "Garage Build"
And Finally a quick little video:
Paint and Color:
Pinch of Gold Flake
Body Mods:
Shaved Moldings
Shaved Antenna
LS7 Lifters
4L60E Transmission:
Corvette Servo
Beast Sunshell
.500 Boost Valve
Racing Band
Shift Kit
Alto Red Clutches
Hardened Pump Rings
Still Left To Do:
Get Wheels/Tires
Finish Interior
Images:
