[WANTED] 1970 Duster rocker panel molding clip part #6002840
Davezilla
Michigan
I am working on a 1970 Plymouth Duster.
I need a few of the white plastic clips that attach the rocker panel moldings to the rocker panel.
The part number molded into the clip is 6002840.
This clip goes into holes in the rocker panel.
It is not the same as the 1971 and later style clip that slides over a pin sticking out of the rocker panel.
I don't know exactly how many I will need yet, because we are still trying to remove them, and some of them are breaking during removal.
Thank you
Measurements are about 1 3/4 inch x 1 inch (1.75"x1").
The first picture is the front side of the clip.
The second picture is the back side of the clip.
There should be plastic fingers around the raised round pin in the center of the back side of the clip, but they are broken off.
I might have them but the dowel pin in the center will have to be made or cut from a long dowel from a craft store. I usually knock the center into the rocker to remove them years ago. Ill look I'll look in the drawer. when I walk to the garage today.
I appreciate you checking for me. Let me know if you find any. It is hard to believe that nobody reproduces this part yet.
