[SOLD] 1970 Duster
dwire67
Seaford, Delaware
For Sale H Code Duster
Non Matching number and no data plate that was how it was found.
I pulled it from a Garage in 1999 Drag raced it to 2007 then did a complete overhaul in 2012 to 2013-everything in the car has less than 1000 miles on it.
I have over 100 pictures of the overhaul. The list is endless of what was done to the car. The car was converted to a 4 speed and power steering
360 engine-Passon built A833 23 spline, A Body 8 3/4 4.10 , 4 wheel disc brakes, Firm feel and Hotchkis suspesion
If you are serious please PM for my Phone Number.
I am open to trades for Older Pickup Truck 48-58 Dodge, Ford or Chevy , Early Ford Lightning Truck or 80 to 89 C10 short bed plus Cash and or anything else interesting. Just PM me the worst I can say is no. No Street bikes or Boats
$18,500.00- open to offers
Very clean looking car - any interior shots to include the rallye dash? Also what are the seat out of?
Is the 4 speed with O/D?
This car looks like it would be a blast to drive - why are you selling?
GLWS.
The rallye dash was removed -has custom made dash
It is a regular 4 speed with with alot of upgrades from Jamie Passon
The seats are Procar cloth seats and the back seat was covered to match
Here is a picture of the dash in progress
Here is a Partial list of what has been done to the car
Engine- early 360 .030-KB pistons -Scat Rods and Scat cast crank
Ported cast heads with 2.02 valves-Comp Cams Stainless steel roller rockers
Crane cam solid lifter 540/560 lift -crane push rods and valave springs
LD 340 intake-Holley 750 DP hand built by Barry Grant
Holley mechanical fuel pump, Mopar performance balancer
All bolts are ARP
Hooker Super comp headers
TTI 2.5 full exhaust
Transmission -Built By Jamie Passon
23 spline A833 street slick shifted
Rebuilt Hurst shifter and new linkage
Pedal assy. refurbished by Jamie Passion
New Z bar and clutch linkage
Mopar Performace Flywheel
Mcloed Borg & Beck style clutch with series 500 disc
3" custom driveshaft with Mark Williams Billet steel yokes
New fuel tank and 3/8 sender and lines
Stainless steel brake lines
4 wheel disc brakes
Hotchkis front sway bar, adjustable strut rods and rear leaf springs
Firm feel stage 3 power steering box, lower control arm pins, 9/16 tie rods
Magnum Force tubular upper control arms and front frame section supports
US Tool Driveshaft loop and torque boxes -all 4
Sub frame connectors
welded k frame with power steering box support
Wizard cool custom radiator
17" Nitto 450 tires 225/50 17 fronts
275/50 17 rears
12 way adjustable QA1 aluminum shocks
New Custom interior
