1971 198 slant six Carb
I have this Carter carb on my '71 198 (correct Carter 1bbl Ball&Ball rebuild by Autoline).
Sold by Rockauto
More Information for AUTOLINE C6018
Looks close but non of my Picts match the 3 they using . Also like Napa - says you can't buy this product as its " not available " for them to even order in the store same goes for Napa , auto zone , advanced , oreileys .
The C6018 that Autozone shows is the correct carburetor. It's the same as you have. It's just not available anywhere. I think if you want that particular carburetor, your only choice is to rebuild it or have it rebuilt.
i saw on vice grip garage video where he buys a duster from Dylan mccool , Dylan had used the very adapter that was suggested me to get and is using the 2bble 318 carb on its Slant . But no air filter lol . My guess cause it's doesn't fit cause I tried it too with factory air box . Anyone seen that video ?
I've not but if it's "that" close to fitting, I'm sure you could use a low profile 2 barrel air cleaner. This is hot roddin fifty plus year old cars, man. You're not going to find anything that falls together without some modification, unless it's dead stock.
When I got my 70 Duster /6 around 1999 it had a Cater on it, changed to a Holly and it became a rocket. Might be the other way around. It came off of an earlier 198 I think. Maybe the jetting was different, I never opened it up.
The Autoline C6018 is available at Rockauto for $209.79 (less the core of $65.00 for your old carb, the C6018 is only $144.79)
RockAuto
found one..
CARTER 4956S BBS CARBURETOR
Carter BBS 4956S & Others, 1970-71 Chrysler Dodge & Truck 198"-225" Motor
Yes but this is not a new one or even operational this is for rebuilding. And they don't have in stock as I was claiming I can't find anyone making new replacement copies like they do the BBD Whicj is what I'm running now . I cut a hole in my hood and put a scoop on it so I could close my hood.
