[WANTED] 1971 340 Ex. Manifolds
Cars and Mopar Parts Wanted
Thread Status:
  1. George Greene
    George Greene Active Member
    36
    27
    Feb 9, 2020
    Nicholasville, Ky.
    Local Time:
    5:46 AM
    Contact Seller
    Looking for a set of 1971 340 Left and Right Exhaust manifolds.
  2. 1500swinger
    1500swinger Well-Known Member
    114
    19
    Jul 2, 2011
    bonnyville
    Local Time:
    4:46 AM
    Date coded i assume?
  3. George Greene
    36
    27
    Feb 9, 2020
    Nicholasville, Ky.
    Local Time:
    5:46 AM
    Not necessarily, the car has a NOM but it is a correct date coded 340, just not the Correct VIN. The car was built June 1971.
  4. daddio4048
    daddio4048 Daddios72
    524
    221
    Oct 18, 2015
    Valdosta,Ga.
    Local Time:
    4:46 AM
    The Hi Po manifolds?
  5. 1500swinger
    114
    19
    Jul 2, 2011
    bonnyville
    Local Time:
    4:46 AM
    I will check i have date coded but are pricey as i am selling that set for when date coding matters. I think I have later sets. Fyi did you check ebay. Some are cheap.
  6. George Greene
    36
    27
    Feb 9, 2020
    Nicholasville, Ky.
    Local Time:
    5:46 AM
    Yes , thanks.
    I have a set and the right side number is correct but the left doesn’t show in the books. 3418621-1 . Date coded 4-29-71
    Maybe it’s correct?
  7. George Greene
    36
    27
    Feb 9, 2020
    Nicholasville, Ky.
    Local Time:
    5:46 AM
  8. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    15,335
    4228
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    4:46 AM
    Not for an A body. Kim
    • Agree Agree x 2
    • davescuda
      davescuda FABO Gold Member FABO Gold Member
      9,864
      1462
      Apr 30, 2007
      Cheshire, CT
      Local Time:
      4:46 AM
      I have a set but not 71 date codes
      • Like Like x 1
      • George Greene
        36
        27
        Feb 9, 2020
        Nicholasville, Ky.
        Local Time:
        5:46 AM
      • daddio4048
        524
        221
        Oct 18, 2015
        Valdosta,Ga.
        Local Time:
        4:46 AM
      • 66fs
        66fs FABO Gold Member FABO Gold Member
        4,678
        1402
        Sep 9, 2009
        Greenwood, South Carolina
        Local Time:
        5:46 AM
      • George Greene
        36
        27
        Feb 9, 2020
        Nicholasville, Ky.
        Local Time:
        5:46 AM
        What are the correct L & R casting numbers that I need?
      • 66fs
        4,678
        1402
        Sep 9, 2009
        Local Time:
        5:46 AM
        2863553 (68-71 A Body 340) LH Drivers Side
        3418623 (71-73 ABCE Bodies 340/360) RH Passenger Side
        See post #9 above. the LH is 72-74 but will work with 71 factory exhaust. RH side is correct.
      • davescuda
        9,864
        1462
        Apr 30, 2007
        Cheshire, CT
        Local Time:
        4:46 AM
      Thread Status:
