DTM would do the cam swap 10x over and buy all the tools with the remainder of the money, no promises it'll ever run again.. But that's his guarantee.
that's a very fair stance to take and i'm in the same camp.Just a guesstimate, but no way in hell anyone is charging me $10k to do ANYTHING to my car. Except maybe body/paint.
laughable dan.10k for a cam swap is ridiculous. If everything needed to do the job would be 3k, that leaves 7k for labor. junkyardhero said something about shops charging $200 an hour, divide $7000 by $200 = 35 hours to swap the cams? I'd say that someone doesn't know what they are doing or they are lazy.
^^^ this right hereIt's fair to point out that that seems like a lot for a cam swap but until/unless it is broken down as to what work is involved, there's no way to know if it is reasonable or not. Heck, maybe that $10k also involves changing a quarter panel or two! We just don't know all the details so no way to know the fairness of the cost.
In all fairness, what would a hydraulic roller cam cost, retrofit hydraulic roller lifters and push rods? Say that the cam would be mild, like just a little bigger than a stock 360 hydraulic roller cam? I know that things are not cheap but 10k.
Things do add up rather quickly. I believe you mentioned that a shop may charge $200 a hour, I'd tell them to put the crack pipe down. A local car dealership doesn't even charge that much. As far as swapping out a cam in 35 hours ,probably not a hydraulic roller cam but a hydraulic flat tappet cam, no problem especially if the car doesn't have ac.you have the internet. google that up amigo. summit or jegs both have pricing easily available.
but keep in mind, it's not just the cam and lifters and some pushrods.
you're likely gonna need new springs to match the roller, which fine because the heads are already off for the roller lifters. but what else do the heads need? count on there being something so there's some dough. then add in a timing chain, because you're there. head gaskets? there's another $200. oil, filter, coolant, there's another $150
**** adds up quick
also, you're stuck on that 10K number. that's not the price for a cam swap. that's a worst possible case situation. get your facts straight, mandingus.
and you'd be laughed out of the garageminivan dan said:Things do add up rather quickly. I believe you mentioned that a shop may charge $200 a hour, I'd tell them to put the crack pipe down.
woo buddy, do i have news for you... dealers out here are all more than 200/hrminivan dan said:A local car dealership doesn't even charge that much.
good luck finding a reputable shop that does modern and classic work. there's one here in town, he's 185/hr and anything vintage takes a back seat to his customer's daily rides. [fyi, dude is stacked with work]. if it's a classic only shop? everybody i know is 6mo or more out for work and not a single one i know of is less than 200/hrminivan dan said:The independent shops here don't go by what year car you have as everyone pays the same amount per hour.
you're fibbin' my dude. with your hips and back? you'd get halfway thru the teardown and give up and sell the car.minivan dan said:As far as swapping out a cam in 35 hours ,probably not a hydraulic roller cam but a hydraulic flat tappet cam, no problem especially if the car doesn't have ac.
**** adds up quick
Tools bought and paid for years ago. I didn't guarantee anything.DTM would do the cam swap 10x over and buy all the tools with the remainder of the money, no promises it'll ever run again.. But that's his guarantee.
I remember asking a car dealership where there flat rate manual was when they tried charging me a hour and a half for a 45 minute job, the job was replacing the EGR valve on our mercury marquis with a 302, those valves are easy to access. I left those clowns and stopped by a parts store and bought the valve and changed it myself in 30 minutes. I'd laugh at them for charging a $185.00 an hour. If he can get it more power to him but it'll be a cold day in you know where before I'd pay a $185.00 an hour.and you'd be laughed out of the garage
Dan - like it or not, here in rural Florida where I am the dealer's flat rate is $205/hr. I suspect it's more as you get close to Orlando or farther south. Just the way it is.Things do add up rather quickly. I believe you mentioned that a shop may charge $200 a hour, I'd tell them to put the crack pipe down. A local car dealership doesn't even charge that much. As far as swapping out a cam in 35 hours ,probably not a hydraulic roller cam but a hydraulic flat tappet cam, no problem especially if the car doesn't have ac.
And what does the mechanic make? The dealership close to me charges $125 - $205 per hour and it's based on the work neededDan - like it or not, here in rural Florida where I am the dealer's flat rate is $205/hr. I suspect its more as you get close to Orlando or farther south. Just the way it is.
No computers, no modules, point to point wiring and tons of space to work. Geez, $200 bucks an hour for a simple brake job or alternator change? Man, I was born in the wrong era. Now, custom tuning, high output race stuff etc...That would be a specialty.if it's a classic only shop? everybody i know is 6mo or more out for work and not a single one i know of is less than 200/hr
laughable.It's all a big rip off. There's no way that it's worth over $90 an hour for mechanical work. If I were a young man I'd open up a garage and put some of these clowns out of business. Unfortunately the newer junk requires a dealership because of all the computers on the newer junk.
go find a shop that'll work on something old. they don't and they won't.No computers, no modules, point to point wiring and tons of space to work. Geez, $200 bucks an hour for a simple brake job or alternator change? Man, I was born in the wrong era. Now, custom tuning, high output race stuff etc...That would be a specialty.
Yes, I see the listing on Summit for that engine, allegedly in-stock (I am NOT waiting 4 months for a damn engine), for 10k. If the bottom end does turn out to be bad or if heads have to come off for whatever reason I am probably going that route. But I'm not jumping to conclusions until they have the intake off and can get a closer look. I don't race or push the engine to extremes so honestly I'm probably fine just staying flat tappet if it's much cheaper and faster, then the bill should be well under 5k.
Seems like a void that needs to be filled. What is this world coming to?go find a shop that'll work on something old. they don't and they won't.
they want quick bang-bang in and out work, they don't want the liability or problems of working on an old car (if something goes wrong) or something that sits around while it burns potential bay space and labor hours searching for or waiting on parts
classic cars are specialty work. there aren't young guys (or gals) out there cutting their teeth doing grease monkey work for $20 an hour any more.
that era is long gone.
Techs make $100 per hour? Holy ****...Not my Nephew.because as a general you need to have *great* techs that can tackle anything and you'll be paying them at least 50% of labor,
the cost of doing business is astronomical. around here, for a small shop just to open the doors monthly the nut is nearly 5 digits. overhead is unreal, the diag/scanner stuff you'd need for most late model jobs really wouldn't be that much of a barrier to be honest. but again, there's that pesky cost of doing business when you have to pay X $'s a month for the subscription to do updates.Seems like a void that needs to be filled. What is this world coming to?
It just seems crazy weird that no one wants $200 per hour to do what we do for fun. I would suspect that overhead for a classic shop would be way less than for a late model shop. Basic diagnostic and hand tools.
