1971 Demon Engine Upgrade 360 EFI
Small Block Mopar Engine
  1. champyfz450
    champyfz450 Well-Known Member
    57
    22
    Sep 14, 2013
    Alberta
    Local Time:
    12:13 PM
    I initially planned on installing a G3 Hemi into my car, but have since changed plans and decided to stick with this setup. Does anyone have experience with the Holley Terminator X ECU and universal wiring harness?
    • Like Like x 2
    • dartgarth
      dartgarth Well-Known Member
      134
      59
      Jul 2, 2010
      Langley
      Local Time:
      10:13 AM
      I haven't used terminator but I have used (and run now) Sniper and have tuned HP systems. What do you need to know?
      I just DL the terminator software and it does have base Mopar tunes but I'm sure one of the chevy tunes will get you started.
      Garth
      • Thanks! Thanks! x 1
      • champyfz450
        57
        22
        Sep 14, 2013
        Alberta
        Local Time:
        12:13 PM
        Just looking for a little feedback on how others' setups (with Holley fuel management) are running. Was it difficult to tune? How was the wiring? Stuff like that, this is my first foray into EFI on an older model vehicle.
      • dartgarth
        134
        59
        Jul 2, 2010
        Langley
        Local Time:
        10:13 AM
        It's pretty easy and the Holly software is very straightforward and user friendly. The wiring is all good too. I found the instructions good as well. I'm here to help if you need it.
        Garth
        • champyfz450
          57
          22
          Sep 14, 2013
          Alberta
          Local Time:
          12:13 PM
          That really means a lot! Thank you. What is your engine setup, if you don't mind my asking?
        • dartgarth
          134
          59
          Jul 2, 2010
          Langley
          Local Time:
          10:13 AM
          383 Big Block, Hydraulic roller cam, Sniper EFI, Sniper Distributor, MSD 6EFI box. At first I wasn't running the timing control and was running a regular MSD Distributor but I'm now running the Sniper distributor and having the sniper control the timing. I also run a A518 trans with Compushift Mini controller. I went Sniper because I wanted it to look "stock" to the layman. oh I also run an electric fan and electric water pump now too.
          • Like Like x 3
          • champyfz450
            57
            22
            Sep 14, 2013
            Alberta
            Local Time:
            12:13 PM
            Nice clean setup dartgarth I really like it! Have you had this setup dyno'd?
            • Disagree Disagree x 1
            • dartgarth
              134
              59
              Jul 2, 2010
              Langley
              Local Time:
              10:13 AM
              Tuned it on the engine Dyno. Made 400 HP @ 5100 RPM and 430 ft/lbs of torque @ 4600 with over 400 ft lbs from 2500-5200 RPM. I think his dyno may be a little conservative but also keep in mind I have a very small Hydraulic roller cam 217/225 @ .050 and .544 lift, 109 LSA, 264/272 gross. It ides with 17" of vacuum and scoots along pretty well with the 3.91 gears.
              • Like Like x 1
              • champyfz450
                57
                22
                Sep 14, 2013
                Alberta
                Local Time:
                12:13 PM
                Those are very respectable numbers. I'll be glad if I'm in mid 400's.
                Does anyone know if stock height/fabricated valve covers will work with 1.6 rockers?
