69KillerFish
Our Father started a resto-mod on the Dart but passed away before he could finish it. It is roughly 75% completed. This car is part of an estate.
What we currently know about the car -
The car was a slant 6. There is a newly rebuilt 383 - 30 over with high flow heads. There is a 727-B trans with column shift. The motor has been installed using a k-frame modifier and Schumacher motor mounts. The engine has a set of TTI headers coated Black. There is a complete 2 1/2" mandrel bent exhaust system (not installed). There is an 8 3/4" rear, not sure yet if it is 3:23 or 3:55. The Dart has front and rear anti-sway bars, frame stiffeners and traction bars. The control arms for the front wheels have been upgraded to handle the weight of the big block and 10" drums all way round. The all Black interior is installed and complete. The car still needs paint and minor body work at the rear quarters. It was trim prepped for Top Banana Yellow.
The car comes with almost every part needed to complete the resto.
Some of the parts -
4 Goodyear Tires Mounted On Black Steel Wheels - 205/70R14's
Big Block Radiator and Hoses
Radiator Fan Shroud (Stainless)
Front And Rear Bumpers (Need To Be Rechromed)
Edelbrock Chrome Valve Covers In Box
Large Diameter Fuel Lines
Master Cylinder
Brake Lines
Engine Accessory Belts
Alternator
Brackets
Spark Plug Wires
Coil
Oil And Trans Dip Sticks
Headlights
Valve Cover And Exhaust Gaskets
Black Seat Belts
4 Bbl Edelbrock Carburetor
Tall Carburetor Gasket
Flowmaster Mufflers 50 series
Exhaust Hangers
Complete Set Of Mandrel Bent Exhaust Pipes 2 1/2"
Header Collector Reducers (2 Sizes)
Stainless Dart Exhaust Tips
Torsion Bars For Slant 6 And Big Block
Drive Shaft With External Balance Ring
Power Steering Box
Hood
Front Grill
Body Emblems And Rump Stripe (Black)
Break-In Oil For Motor
Electronic ignition
Marker lights
Emergency brake cables
Battery cables
Valve cover breather cap
We are asking $12,500. The car is located in Anne Arundel County, Maryland. If you are interested in the car, please feel free to PM me with any questions. There are more pics available.
[/ATTACH]
Some of the parts -
Master Cylinder
Brake Lines
Alternator
Brackets
Spark Plug Wires
Coil
Headlights
Black Seat Belts
Exhaust Hangers
Power Steering Box
Hood
Front Grill
Electronic ignition
Marker lights
Battery cables
[/ATTACH]
