1971 Plymouth Duster with 3.7 225 Slant six Idles very rough
Mopar General Discussions
  1. Donniedon
    Donniedon Member
    7
    0
    Dec 6, 2020
    Tujunga, California
    Local Time:
    10:35 PM
    I've had my '71 Duster engine rebuilt, as well as the Holley 1 bbl. carburetor. The mechanic I use suggested that I use Pertronix Distributor, and go pointless. It seems ever since, my idle has been very rough. Idles too fast, and really rough.
    1.) Electrically- - - completely new wiring harness throughout car, new alternator, spark plugs, coil, ignition wires.
    2. With regards to fuel intake- - - Rebuilt 1 bbl Holley Carburetor, new vacuum lines, hooked up properly, new fuel pump, new fuel filter, new gas tank ( total parts).
    3.) With regards to exhaust-- - new exhaust manifold, new single tailpipe, new muffler, and continued new tailpipe to rear bumper.
    I don't know what is going wrong. Any suggestions /advise would be welcome.
  2. rklein383
    rklein383 Well-Known Member
    1,647
    572
    Dec 2, 2005
    Local Time:
    12:35 AM
    This is usually a process of elimination but since it has been upgraded to electronic. Make sure you have good ground from the engine to the frame. Since it is idling fast, that seems to indicate an air/vacuum leak somewhere.
  3. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    48,856
    17019
    Oct 14, 2010
    Idaho
    Local Time:
    10:35 PM
    Along with "the usual"
    Carb even though gone through may have a problem or not adjusted correctly, vacuum leak, timing bad plug or bad plug wire, bad valves or if valves adjustable, not set correctly, and on we go
    BUT ONE possiblility is that somehow the Pertronix is AFU or installed wrong and you are suffereing from what is called (bad) "rotor phasing"
    Google it several articles and videos on the www. This means that due to some problem in the distributor, the pickup device is not firing the spark when the rotor is actually pointing at a plug wire distributor cap contact
    Ignition Systems - Rotor Phasing Article by MSD Ignition | Hotrod Hotline
  4. Slantsix64
    Slantsix64 Well-Known Member
    3,029
    1236
    May 11, 2014
    SGV
    Local Time:
    12:35 AM
    Always always on a slant six adjust the valves first. Tight valves will give a rough fast idle.
    • Agree Agree x 1
    • Donniedon
      Donniedon Member
      7
      0
      Dec 6, 2020
      Tujunga, California
      Local Time:
      10:35 PM
      Thanks! I will look into ALL of the items suggested!
    • ESP47
      ESP47 Well-Known Member
      1,829
      306
      Jul 3, 2009
      Sacramento, CA
      Local Time:
      10:35 PM
      I vote vacuum leak. Most likely at the intake to head connection.
      The valves are probably too tight as well. slantsix.org has a write up on how to do the adjustment correctly.
