restoring a 1972 340 duster,,,looking to install a cam with a decent lope,but dependable on the street,,,looking to work heads (larger valves,,porting,,,valve guides,,and bore cylinders,,any suggestions on cam specs and cam make.
thanks for reply,,,,4-speed,,,3:23 rear gears,,eldebrock intake,,,Knowing a bit more about your ride will help man. Auto/Manual, gear ratio, torque converter etc.
Be well,
Pat
