1972 Demon fender top blinkers
Electrical and Ignition
  1. Markzilla88
    Markzilla88 Well-Known Member
    82
    18
    Oct 4, 2019
    Maryland
    Local Time:
    4:09 AM
    I was just wondering if anyone could lend a bit of knowledge and has a picture or can describe where the fender top blinkers connect to in the wiring harness? I can’t seem to find a female connector for them loosely laying around anywhere in the front of the car. Thanks!
  2. doug 371
    doug 371 Well-Known Member
    2,146
    352
    May 29, 2004
    Regina, SK CANADA
    Local Time:
    9:09 AM
    follow the front side marker wiring
  3. MoparMike1974
    MoparMike1974 FABO Gold Member FABO Gold Member
    3,092
    2340
    Jun 16, 2017
    Maryland
    Local Time:
    4:09 AM
    It should be a single wire popping out of the lighting harness up near the radiator support area. I have seen some that did not have that wire before and had to tap into the front turn signal wire.
  4. Markzilla88
    82
    18
    Oct 4, 2019
    Maryland
    Local Time:
    4:09 AM
    Yeah, so I did trace that wire back and didn’t see any pig tails for it to connect in to. I’ll keep looking but I don’t think there is one. I’ll have to look into how to tap into the side marker lights to get them tied in.
  5. CRUZE 418
    CRUZE 418 FABO Gold Member FABO Gold Member
    684
    280
    Mar 11, 2019
    Illinois
    Local Time:
    3:09 AM
    It's a bullit connector on my '72 Dart, goes out through the inner fenderwell.
  6. MoparMike1974
    3,092
    2340
    Jun 16, 2017
    Maryland
    Local Time:
    4:09 AM
    Yes, a single bullet connector. The housing itself is the ground.
  7. Markzilla88
    82
    18
    Oct 4, 2019
    Maryland
    Local Time:
    4:09 AM
    I definitely appreciate all the help here, thank you all. I went through the harness again and did not find a bullet connection anywhere for the blinker to plug into. If I were to tap into the wire for the actual blinker on the side of the fender, how would I go about that? Is it as simple as exposing a section of wire there, soldering in a bullet connector there, then just making the connection?
  8. MoparMike1974
    3,092
    2340
    Jun 16, 2017
    Maryland
    Local Time:
    4:09 AM
    I think its part of the A01 light package.
  9. CRUZE 418
    684
    280
    Mar 11, 2019
    Illinois
    Local Time:
    3:09 AM
    Just deleted my last post, I was totally wrong. That bullet connection is woven in with the side marker light, which drops down from the headlamp plug harness. There is a hole in the bottom of the headlamp bucket for the side marker harness. I am not an electronic guy, don't know if just tapping into the harness works.
    Give it a try with a test light.
  10. Markzilla88
    82
    18
    Oct 4, 2019
    Maryland
    Local Time:
    4:09 AM
    Oh wow, no way. Alright cool, I’m gonna go look even harder to see if it’s down there hanging out. Thanks again for all the work!
