[SOLD] 1972 Dodge Demon
Kraftei
Active Member
Stony Plain, Alberta
Rating - 0%
0   0   0
1972 Dodge Demon - factory H code 340 / 4 speed - none matching numbers - the concept was a car that looked period correct / representative of the 70's ! The car is a crowd pleaser where ever it goes, gets the most attention of any car I have owned.
Stony Plain Alberta $58,000.00 CDN, $43,000.00 US
1968 340 Full Roller, Holley 780, Single Plane Mopar Intake, Holley 780 vacuum Secondary, Full MSD Ignition System, Milodon Oil Pan, Ported Heads and Intake, X Heads, HP Exhaust Manifolds, Electric Fuel Pump
Fresh Rebuilt A833 Transmission, Hurst Shifter, Centerforce Clutch, Balanced Drive Shaft
Fresh 8 3/4, 373 gears, Detroit Truetrac, Adjustable Pinion Snubber
Complete new Interior, Dash Restored
Approx 300 miles on car, the shell was painted, bottom was then undercoated. I spent approx $20,000 going over the car last winter, basically took it to the next level, needs nothing. I had the car professionally wet sanded (77 hours), buffed, new decals, new flat black paint on hood, front chin strap and wing, ceramic coated. Paint is next level.
Link to car running:
