1972 Duster lockstrip??
Mopar Body and Trim
  1. Duh-Star
    Duh-Star it runs....sorta... FABO Gold Member
    41
    9
    Jul 1, 2017
    Parker, Arizona
    Local Time:
    4:37 PM
    I decided to replace my crappy pitted windshield and I spoke with a (self described) tech at Classic Industries who swore I would require a lock strip to go with my windshield gasket. I also purchased a gasket for the rear glass because it leaks. Again, I was informed that a lock strip was required. I started pealing back the windshield gasket today and I do not see a lock strip. A quick perusal of this site showed a lock strip required for a 1967 Barracuda, but not much info on a 1972 Duster.
    Q-Do I need this lock strip for my windshield/ rear glass gaskets? Did they not come originally on this model? Is it useful to install them even if they are not original?
    Thanks for any info you can provide.
  2. Kern Dog
    Kern Dog FABO Gold Member FABO Gold Member
    6,169
    15196
    May 23, 2010
    Granite bay CA
    Local Time:
    3:37 PM
    All Dusters, Demons and Dart Sports use windshield gaskets that use a round lock strip to effectively seal the rubber to the glass. I bought 3 rolls of it at my local auto glass supplier for my projects current and future...
  3. dcl68
    dcl68 FABO Gold Member FABO Gold Member
    243
    302
    Nov 8, 2010
    Buffalo NY
    Local Time:
    6:37 PM
    It is needed for the proper seal for sure.
  4. Duh-Star
    41
    9
    Jul 1, 2017
    Parker, Arizona
    Local Time:
    4:37 PM
    great!
    Thank you for the clarification!
    I will proceed....
  5. zkx14
    zkx14 Duster De-ruster FABO Gold Member
    29,128
    26921
    Dec 23, 2012
    South Central PA
    Local Time:
    6:37 PM
    If the gasket has a gap for the strip, you must use one.
  6. Fgill
    Fgill Well-Known Member
    219
    252
    Feb 16, 2015
    ut
    Local Time:
    5:37 PM
    i have run into cars that did not have a strip in the channel (??) I assumed at some point soemone was in there replacing glass, gasket or pulling the dash or something and never replaced it. Not uncommon to not have one after 50yrs & multipel owners, at least in my experience.
  7. Duh-Star
    41
    9
    Jul 1, 2017
    Parker, Arizona
    Local Time:
    4:37 PM
    ...well, that would explain the leaking issue!
    thanks!
