My foot pump rubber was deteriorated and split in half , I found that the mustang rubber for that washer pump is reproduced and the same size as Mopar on the Duster , I hope someone else has done this , question is I can get all the pieces inside the boot easy enough but should it be sealed to the flat piece that has the threads with some type of sealant and or is there an o-ring that goes on between the threads an the bottom fitting that the lines go on , just want it sealed properly and know there has to be something
