crj1968
1972 Plymouth Duster. (Not original 340 car)
It's back-
340
727 shifts good / strong
8.75 Sure Grip (3.91s?)
Front Disc Brakes (new brakes all around)
5 on 4.5 Bolt pattern
Solid floors, trunk and rails
Runs and drives decently enough. Will torch the tires, no problem
needs some body work (mainly tail-light panel...new ones are available at AMD...probably your best bet to just replace it... and dent in hood)
needs some wiring cleaned up...(turn signal switch- but lights/signals all working)
Lumpy cam.
Behind that air cleaner is big one wire HEI distributor/coil combo... fyi, ugly but it does work really well.
New fuel tank
Edelbrock Carb
Newish BFG's
What does it need? Run and drives as is, but to make a decent looking daily driver, $5K thrown at it would go a long way, depending on your own abilities, of course.
$11,500 cash no trades.
Can store car for a while as shipping arrangements are made.
some links:
www.youtube.com/watch?v=j8LIB7tksTM
www.youtube.com/shorts/-HLvcFATiP4
1972 Plymouth duster 340 727 Mopar - cars & trucks - by owner -...
It's back-
340
Lumpy cam.
New fuel tank
Edelbrock Carb
Newish BFG's
some links:
