soonercruiser
I've been going thru this problem on the AllPAR Forum with no final resolution.
I am fixing up a 1972 Duster that just gas some racing mods; but pulled a lot of other stuff off the car that I consider necessary.
Like the horns! None there - but the pigtails were there.
Horns high 7 Low are now new, they sound great!
But...no power when horn button pressed.
Eventually discovered that they had pulled the horn relay too. Duh!
Bought a new horn relay....still no power to horns when horn button depressed.
See the diagram below of the horn relay connector:
"L" is hot!
When I jump a wire from "L" to "J", the horns sound! So, the wire (red with green tracer) to the bulkhead connector and horns is OK.
Someone had me try to jump a grounded wire to the steering wheel ground, and push the horn button - did not work.
As I said previously, the previous owner pulled a lot of stuff out. Maybe the ground wire at the column is not grounded properly?
Does anyone know what color wire that ground would be in the steering column harness?
The beautiful, expensive wiring diagram is no help here. As the horn wires is shown only going back to the "L" horn relay connector; ending there.
"L" is hot!
