dirtybird4408pack
Member
Located near Phila Pa
1972 Pro Stock Duster former Pro Stocker of Gary Lapone in Northridgeville Ohio. The name of the car was El Pistolero from Division #3
Engine 452 stroker
Wisco 10.5 to 1 pistons
Eagle rods
440 steel crank cut to fit 400 HP-2 block
Milodon pan with dual pick ups
Dual oil filters
Melling pump
Comp roller cam, lifters, pushrods, springs, timing chain and gears
1.5 Harland sharp rockers
Indy intake tunnel ram max wedge ports
2 1050 dominators flowed to 1300 cfm matched set
Aerospace fuel pump, filter, press regulator 4 port, and gauge
Indy pro series carb linkage
MSD 7 al-2 pro power coil and distributor
Taylor wires
TCI torqueflite 727 manual valve body and oil cooler
6300 stall converter
Dana 60 456 gears and spool
Mosier Pro axles
Comp shocks x 4 3 way adjustable
Comp wheelie bars old school
Simpson drag chute
New fuel cell
2 new batteries and cables
New aluminum radiator
2 Moroso D S/2 front tires on old super tricks
2 E/T M/T 14x32x15 drag slicks with 2 new tubes also on M/T on old super tricks
Car runs 9.88 as is 8.66 with 586 gears and Lenco 5 speed
Much more...
$15,000 car must go need room.
Engine 452 stroker
Eagle rods
Dual oil filters
Melling pump
Taylor wires
Mosier Pro axles
Simpson drag chute
New fuel cell
Much more...
