1972 vs 1973 Dash Wiring Harness
Jim Kueneman
Sonoita, Az
I have a '72 Duster that I am going to put a '73 Dart dash and AC system in. I am trying to decide what to buy from a dash wiring point of view. The M&H harnesses from Year One have a '72 A Body and '73 A Body that are over $100 different. I have looked at the schematics for the 2 years and there is very very little difference. Anyone have any thoughts on what the '73 harness would have that would make it $100 higher cost?
im not sure the 73 a/c box will bolt right in a 72 it definately wont bolt right up in a 71
I think the only difference would be extra stuff like seat belt buzzers and such.
I used a 73 harness in my 72. Not too much difference that I remember. I had to add a wire for the passenger door switch, I think. My AC/Heater box is not functional, so can't comment on that, but everything connected.
I found the 73 harness in great shape on here from a member for $100 shipped, I would post a wanted ad first.
*ALSO- read the disclamer on the Year One description for the harnesses about the connectors. Not sure if they are saying some are unavailable and missing???
I'm not 100% sure, but check your firewall cutouts carefully.
For the wiring, check the cavity pinout, especially the alternator and fusibile link connectors. I know they vary between 73 and 75.
[el5dart]
I have already cut the firewall patch out of the '73 and welded it in the '72 so the physical installation of the '73 AC/heater box is already handled. The schematics show that the firewall plug pinout is exactly the same between the years.
[KnuckleDuster]
Thanks but I have the harness out of the '73 but I won't use 50 year old harnesses. I waffled on this with my Coronet until I started using some of the 50 year old harnesses and the blower motor switch connector got so hot I could not tough it because of the high resistance due to the years of corrosion in the factory crimp. If I had the energy to remove every connector and find every splice and solder them maybe but with as much money I am putting into the restoration a $400 harness is worth it.
Only difference between 72 and 73 that I can think of is are the connections for the heater/blower.
74 is when things got crazy under there
You do know? About the service manuals and wiring diagrams at MyMopar? Not sure all the 72's had electronic ignition. May have been split year/ option There were changes in smog equipment as well over the years 70--76 so check that out.
Yup that is what I have been studying
The M&H wiring I bought for my 73 Sport from year one had a few pins in the wrong place. I am sure you also know there is an inside a/c harness and an outside a/c harness. The new wiring is very easy to use and I don’t regret spending nearly a grand on all I needed.
No regrets on my Coronet either. The sense of security that there will be no wiring gremlins and no fires on the side of the road is worth a grand to me as well.
