1973 360 Air Cleaner, Demon 1900 Carb
Small Block Mopar Engine
  1. LS&S
    LS&S Active Member
    35
    15
    Jun 9, 2019
    Aylett, VA
    Local Time:
    3:51 AM
    I purchased a Moroso 65910 air cleaner, only to find that the electric choke on my Demon 1900 carburetor protrudes out too far for the base plate to sit down on air horn. Weiand 8007 intake manifold, 1973 360 V8. Any suggestions on air cleaner that gives hood clearance are appreciated.
    DOH!
  2. zombywoof
    zombywoof Well-Known Member
    439
    176
    Nov 2, 2014
    in the dog house
    Local Time:
    2:51 AM
    • Like Like x 1
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      73,310
      48803
      Jun 7, 2010
      Georgia
      Local Time:
      3:51 AM
      A small spacer between the carburetor and air cleaner will solve it.
      • Like Like x 1
      • RustyRatRod
        73,310
        48803
        Jun 7, 2010
        Georgia
        Local Time:
        3:51 AM
      • sireland67
        sireland67 FABO Gold Member FABO Gold Member
        9,625
        3880
        Oct 27, 2010
        WV
        Local Time:
        3:51 AM
        I used a stock 70 E body air cleaner on my Duster and it cleared fine, but a stock 72 trap door hit the hood.
        • Like Like x 1
        • LS&S
          LS&S Active Member
          35
          15
          Jun 9, 2019
          Aylett, VA
          Local Time:
          3:51 AM
          Stock 73 trap door hits the hood. I'm afraid raising 1" will cause same problem. Is there an aftermarket air cleaner that works with 1900 electric choke?
          I think a stock e-body air cleaner would be expensive. OTOH I need to pay whatever to make this work. Did you use it with an electric choke carb?
          • Like Like x 1
          • 70 Buster 340
            70 Buster 340 Carbon Footprint FABO Gold Member
            1,364
            1668
            Aug 9, 2019
            Space Coast, FL.
            Local Time:
            3:51 AM
            Try double or triple air horn gaskets or 'wack a dent' right where the base interferes.
            Maybe...
          • LS&S
            LS&S Active Member
            35
            15
            Jun 9, 2019
            Aylett, VA
            Local Time:
            3:51 AM
            I may have to use the base plate from a Demon air cleaner, 14x2 filter and the Moroso top lid. Demon lid rises too high at center.
          • forphorty
            forphorty Well-Known Member
            756
            359
            Jan 19, 2006
            Local Time:
            2:51 AM
            That base has quite a drop. Do you need one that drops that low? A dropped base combined with a 2 inch element will be pretty restrictive.
          • sireland67
            9,625
            3880
            Oct 27, 2010
            WV
            Local Time:
            3:51 AM
            Yes my carb has an electric choke.
            • Like Like x 1
            • LS&S
              LS&S Active Member
              35
              15
              Jun 9, 2019
              Aylett, VA
              Local Time:
              3:51 AM
              I need it for hood clearance. I'll need to measure the opening between the base and lid. We'll see. No parts on hand yet
            • Bewy
              Bewy Well-Known Member
              619
              328
              Jan 1, 2021
              Australia
              Local Time:
              5:51 PM
              Depending on how much clearance you need, some 'work' with a ball peen hammer might get the desired clearance.
              • Agree Agree x 1
              • LS&S
                LS&S Active Member
                35
                15
                Jun 9, 2019
                Aylett, VA
                Local Time:
                3:51 AM
                LOL. BFH, always there as a faithful last resort.
                • Like Like x 1
                • LS&S
                  LS&S Active Member
                  35
                  15
                  Jun 9, 2019
                  Aylett, VA
                  Local Time:
                  3:51 AM
                  Internal clearance with Demon air cleaner and 14x2 is about .5 inch at widest point on base plate, before the drop
                  I did not like that, so I went with 14x3 in Demon kit to get an extra inch internal clearance.
                  Hood clearance, about 1 inch with 14x3 before stud and fastener
                  Big fastener in kit, decreases clearance to 1/4". I used short butterfly nut and ended up with about 5/8 inch clearance at center.
                  Thanks for the advice! Car is 1973 Monaco, so you need to make your own measurements.
                • Nat
                  Nat Well-Known Member
                  616
                  348
                  Jun 11, 2019
                  Netherland
                  Local Time:
                  8:51 AM
                  stock 340 air cleaner works on my Dart as well as the Demon air cleaner that came with my street demon 850 , both clear the choke and fit under the hood with a victor 340 intake
                  • Like Like x 1
