1973 Dart 225/904 Cooler Line Routing
rstepano
Active Member
Georgia
This is a repost - I believe I posted in the wrong forum before.
I am trying to help a friend out with his 1973 Dart Swinger with 225/904. He removed the trans cooler lines and purchased new ones. I stopped over to help him out, but I cannot figure out how these are supposed to route around exhaust down pipe , motor mount, or power steering pump. Would anyone have photos showing the correct routing of these lines?
Much appreciated.
I found two photos showing them installed. They aren't great — I was really taking pictures of other objects. The brief answer is, they go around and behind all of these objects. It is a pain to install them even when the motor is out of the car, because they have to go around the exhaust manifold and the motor mount at the same time, so you have to wiggle them into place as you are lowering the motor, and keep adjusting them as it goes down, and they try to hang up on everything.
Note that I had an exhaust gasket blowout in this pic. The rubber tubing around the pipes is to keep them from rattling.
