[FOR SALE] 1973 Duster, Injected ,675 hp pump gas , pro touring , over drive
panheadchuck
USA
Rating - 0%
0   0   0
73 Plymouth Duster
27,500 Firm.
75K spent
eng compartment pic is dirty sorry , i hav vids , pics , whatever you want to see just let me know
ZERO MILES
the ride height and alignment are not done yet , this build has zero miles
73 Duster original /6 three on the floor
one year old PPG Deltron Lemon Twist , Phoenix Graphics 340 call outs and stripes
Bumpers were restored and re chromed
new tail light bezels
NOS tail lenses
Torque Boxes welded in at all 4 corners
Usct Level 3 Chassis stiffening Kit
tor boxes all four corners
frame connectors both welded to the floor all the way down both sides of each
USCT HD radiator support with 26" opening
USCT Inboard spring relocation
underside of car and inside lower quarters sprayed with chassis saver satin black
door and hood hinges rebuilt better than new
Mini tubbed
Suspension
Front: Carl Gerst tubular suspension and k member
Manual Rack and pinion steering with Viking double adjustable coil over shocks
Rear : Carl Gerst Triangulated four link, Viking double adjustable coil overs
8.75 narrowed 4" new strange 489 center with chromoly 1350 yoke
rear is back braced and powdercoated
3:91 gears Strange 35 spline spool
strange big pattern 35 spline axles
Engine :
675 HP@ 6300 RPM
604 TQ @5000RPM
on pump gas , g=but is able to run e85 as well and who knows what hp
422 Cid sbm
11:1 Compression
BILLET 4 BOLT SPLAYED MAIN CAPS
m-77 bearings
Custom Diamond Pistons
Trend tool steel 927 pins
Callies 4" Crank 2.100 pin
Callies Rods
tools steel pins
Milodon Pan7 Qt Pan and windage tray
Arp main studs
Arp Head Studs
Custom Solid Roller cam 650 lift 265@.050
Trend heavy wall pushrods
Bushed lifter bores
Erson link bar solid roller lifters
hv oil pump
CNC PORTED INDY W2 ALUMINUM HEADS WITH EXTREME DUTY VALVES 2.100/1.60
JESEL SHAFT ROLLER ROCKERS WITH OIL SPRAY BARS IN THE FABRICATED VALVE COVERS
powerbond sfi damper
Induction
MASS Air (MAF sensor hidden under carb style aircleaner)
Ported Indy 360-1 Intake with injector bungs welded in
1100 cfm pro m black anodized throttle body
billet rails
ptfe lines
Eight 52 lbs/hr injectors sequential point
aeromotive reference fuel pressure regulator
the harness and ecu have wiring for
Boost control
N20
timing retard
water / Methanol
i just wrapped the wiring in the harness but easy to hook up and you just enable it in the program easy peezy .
Trans:
Reid sfi bellhousing for sbm or new hemi
Extreme Automatics Stage Three 200r4 All billet internals
trans brake
billet 3000 stall converter
sfi flexplate
xtreme shift auto/manual valve body constant pressure
OE console shifter modded for an 4 speed auto
Brakes : 4 Wheel wilwood 4 piston drilled and slotted
DR Diff manual master cylinder
DR Diff Prop valve adjustable
nickel chrome brake lines and braided hoses
Fuel
Hyperfuel 19 gallon fuel cell in trunk
450 LPH Walbro pump in the fuel cell with baffles
Aeromotive regulator
fuel lab 10 micron filter mounted under car
Fragola 6000 series -6 hose supply and return ptfe lined braided steel and black coated
Exhaust
TTI thermal and ceramic headers
3" stainless custom tig welded duals with x pipe black widow venom 250 stainless mufflers and stainless tig welded tails with duster tips
interior
all legendary interiors door panels and seat covers / foam
console has been epoxy painted and the woodgrain removed for carbon fiber wrap
auto meter carbon fiber gauges in the dash with gps speedo
all woodgrain was converted to carbon fiber
dual inovate wideband controller gauge in the dash
heater deleted as well as controls
( comes with a professionally restored heater box.and the controls , i just bolted a plate over the motor hole in the firewall so can be easily put back)
tuff wheel
led dash lights with dimmer
POWER LOCKS
POWER WINDOWS
STARTER DISABLE
KEYLESS ENTRY
car needs no tuning , but is completely laptop tunable and i will give a laptop with software with the car .
this is NOT generic 2500 dollar injection this is a custom mass air system built for this car with oem parts and was well over 6500 dollars
Program and this setup can control WITH NO ADD ON BOXES
boost
boost timing retard
water/ meth
nitrous
its all in there and there is wiring in the harness capped off if you want to add any of that
Wheels and tires have no miles
billet specialties street lite
15x7 225/60/15
15 x 12 325-50/15 nitto drag radials
theres probably 100 things im forgetting this is one bad *** duster
Car is located in Hudson Colorado 80642 . About 25 Mi north of Denver
I have vids , i have pics , i can facetime the car to a potential buyer
you do not need to know how to tune a car , it will run beautiful the way it is . but the option is available to do so
73 Plymouth Duster
35K OBO make a reasonable offer . very limited partial trades of pew pew maybe
75K spent
ZERO MILES
NOS tail lenses
Mini tubbed
Suspension
Engine :
675 HP@ 6300 RPM
604 TQ @5000RPM
422 Cid sbm
11:1 Compression
m-77 bearings
Callies Rods
tools steel pins
Arp main studs
Arp Head Studs
Bushed lifter bores
hv oil pump
Induction
billet rails
ptfe lines
Boost control
N20
timing retard
water / Methanol
Trans:
trans brake
sfi flexplate
Fuel
Exhaust
interior
tuff wheel
POWER LOCKS
POWER WINDOWS
STARTER DISABLE
KEYLESS ENTRY
boost
boost timing retard
water/ meth
nitrous
15x7 225/60/15
Your box is full
did this car come from Colorado springs with a 318/727 in it??
I'm glad it got the love it deserved
Stock block?
View attachment 1715550441 View attachment 1715550442 View attachment 1715550443 View attachment 1715550444 View attachment 1715550445
i got it in a trade deal a handful of years ago in Denver. I had a ford lightning. And a guy traded me a Lemans and the duster it had a 318 with aburnt valve and 727. The car used to be a three on the floor so they put a plate over the shifter hole and mounted rhe floor shifter there
could you post some pics of the interior ? thanks Red B.
Its pretty disty as i havent detailed the inteior yet , glove box door is off i am waiting on a new glovebox liner
and ordered a new shifter knob
everything is new
woodgrain gone. Carbon fiber in
tastefully.
everything is new
tastefully. View attachment 1715550696View attachment 1715550697View attachment 1715550698View attachment 1715550699View attachment 1715550700View attachment 1715550696View attachment 1715550697View attachment 1715550698View attachment 1715550699View attachment 1715550700
Well 2 buyers backed out in five minutes.
So car is still for sale. 28,500 final offer. If it doesnt sell in a few days. Ill keep it.
i have actually installed the interior since and set pinion angle since i posted this . car is going for the alignment of the new suspension tomorrow . there are three things left to do,
tune in the idle a little . air screw adjustment
install the new glove box liner ( not here yet) and put the door back on
straighten up and zip tie some of the underdash wiring , just tucking the harness away and securing it . and drive it
Have a list of things that need to be done to it for it to be finished?
