1974 Dart Sport 489 Differential Question
Transmission and Drivetrain Tech
  1. Warren
    Warren Active Member
    35
    1
    Dec 30, 2009
    Local Time:
    1:20 AM
    Hello, my Hang 10 purchased used came with the dealer sticker and originally was a 318 with a 3.23 axle ratio. It now has a 360 and a 8.75 489 differential case. According to my factory manual, 1974 Darts did not have the 8.75 available so my question is:
    Is my 8.75 489 case a retrofit or were there some 1974's supplied with the 8.75 489 from the factory?
    Thanks.
  2. partsman1965
    partsman1965 Well-Known Member
    444
    46
    Jul 16, 2013
    Bourbonnais, Illinois
    Local Time:
    1:20 AM
    74 318 should have been 8.25..does the 8.75 have large bolt pattern?? I'd bet it was from earlier year? I have a 74 with 1970 8.75 but it still has small bolt pattern.
  3. OldmanRick
    OldmanRick Well-Known Member
    7,097
    318
    May 11, 2012
    Ladson, Sc
    Local Time:
    2:20 AM
    Yes...^^^^^....Never seen a 74' A body with a 8.75. And a ratio in that range would have been a 3.21 with a 8.25. It would be interesting though if it was by chance a dealer installed rear? Just be glad you have what you have.....You're $$$ ahead of the game. :thumbrig:
  4. 74DartSwinger360
    74DartSwinger360 The Brat Pack
    4,651
    113
    Apr 16, 2012
    Valrico, Florida
    Local Time:
    2:20 AM
    No A Body after 72 ever had a factory installed 8 3/4 this was also the same year they got rid of Small Bolt Pattern. (except some 73 Slant 6 Stripper cars which had 4 wheel drums)
    So If it is Big Bolt Pattern the axels were swaped or drilled out
    1974 with a slant 6 or 318 would have been a 7 1/4 or 8 1/4 from the factory
    8 1/4 being an added cost option
  5. Warren
    35
    1
    Dec 30, 2009
    Local Time:
    1:20 AM
    Thanks everyone for the info. Yes the axles are the big bolt pattern as have the original Rallye wheels with largeacorn center caps. I did find a receipt where the axle stud plates were welded up and re-drilled by Moser in 1993 so I assume the axles are not original. I have a lot of receipts of this car but no info on the differential other than a 4.10 ratio gears installed in 2000. I have since replaced that with a 2.94 for better economy and hiway cruising.
  6. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    16,972
    5699
    Dec 7, 2006
    PLANT CITY FL. and PERRY GA.
    Local Time:
    2:20 AM
    If the small bolt pattern axles were re drilled then they would have had to re drill the brake drums also. The A-body 8 3/4 small bolt rear used a axle offset specific to this rear end. Are the drums drilled also?
  7. cosgig
    cosgig MoBro Inc. FABO Gold Member
    11,281
    4395
    Jul 20, 2008
    Pinckney, Michigan
    Local Time:
    1:20 AM
    Also, NO A-body 8 3/4" ever came with anything other than the small bolt pattern!
  8. Warren
    35
    1
    Dec 30, 2009
    Local Time:
    1:20 AM
    Sgbarracuda:
    I am not sure the brake drums were drilled (or just replaced) but my memory says there is a 5 hole drilled spacer plate between the drum and axle (I would have to remove a wheel to confirm).
