Is there a 1974 book that has a visual view of this part. I know is was bad and its no good but I want to remove it without causing a big issue.
Thank in advance.........Ted
All you need to do is locate the box under the hood with the reset button. There will be 2 yellowish wires, which are the "start" signal to the start relay. Just permanently wire them together
Seems you got it covered,Good Luck, i dealt with it for 18 months b4 i changed wiring, so remove the reset button and pray your under the dash module is not corroded or fried
