1975 duster 360
Mopar Exhaust Systems
  1. Chuckles1980
    Chuckles1980 Member
    14
    3
    Nov 3, 2017
    Marshall
    Local Time:
    12:54 PM
    What would the exhaust manifold casting numbers be on a 1975 duster 360 with a 4 barrel.
  2. H22A4
    H22A4 Well-Known Member
    1,537
    409
    Aug 4, 2006
    YVR
    Local Time:
    9:54 AM
    Left is 3614368
    Right is 3418623
    Those are the same casting numbers that were used on the 340 A bodies starting around 1972 up to when the 360 A body production ended a 1976.
  3. Chuckles1980
    Chuckles1980 Member
    14
    3
    Nov 3, 2017
    Marshall
    Local Time:
    12:54 PM
    Is this information in a book or a website somewhere
  4. d55dave
    d55dave Well-Known Member
    2,332
    808
    May 20, 2010
    Kelowna, British Columbia
    Local Time:
    11:54 AM
    I believe one or both of them are also thd same for e body.
  5. H22A4
    1,537
    409
    Aug 4, 2006
    YVR
    Local Time:
    9:54 AM
    Have you considered googling those casting numbers to see what pops up? That would be a way for you to some double checking now that someone has kicked things off.
  6. Chuckles1980
    Chuckles1980 Member
    14
    3
    Nov 3, 2017
    Marshall
    Local Time:
    12:54 PM
    I actually can't find the creek casting numbers for a 75 360. According to what I looked up 74 on back is different
  7. H22A4
    1,537
    409
    Aug 4, 2006
    YVR
    Local Time:
    9:54 AM
  8. Chuckles1980
    Chuckles1980 Member
    14
    3
    Nov 3, 2017
    Marshall
    Local Time:
    12:54 PM
    Looks good to me thanks
  9. Treblig
    Treblig FABO Gold Member FABO Gold Member
    5,248
    2255
    Oct 5, 2013
    South Texas
    Local Time:
    11:54 AM
    Has anyone ever seen 340 manifolds on a 360 (from the factory)??? I've never heard of 360 engines fitted with 340 manifolds (from the factory). I know they will work. Is there any documentation on this issue?? Inquiring minds want to know.
    treblig
  10. Chuckles1980
    Chuckles1980 Member
    14
    3
    Nov 3, 2017
    Marshall
    Local Time:
    12:54 PM
    some people say they are some people say they're not. I went to a lot of mopar shows Last Summer and every 360 duster I've seen was either not original or was a 74 so I have no way of knowing
  11. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    10,443
    1290
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    11:54 AM
    75 has a bell flange on the drivers side as well. At least on my factory original car with 40,000 original miles. The. NUmbers are hidden behind the heat stove. My car also has the smog pipe crossing over at the back of each manifold Mine came with a smog pump. Mine is a Canadian built car. Kim
  12. RustyRatRod
    RustyRatRod 30 Degrees Outta Whack FABO Gold Member
    49,148
    15342
    Jun 7, 2010
    Georgia
    Local Time:
    12:54 PM
    Lil Red Express?
  13. Treblig
    5,248
    2255
    Oct 5, 2013
    South Texas
    Local Time:
    11:54 AM
    Yea, a "bell" means 1 5/8" exit hole. The 340 has a flat flange.
    Treblig
  14. Treblig
    5,248
    2255
    Oct 5, 2013
    South Texas
    Local Time:
    11:54 AM
    I was referring to A body cars but then again....I've never had a good look at a Lil Red Express motor??? Are there any others you can think of??
    treblig
  15. RustyRatRod
    49,148
    15342
    Jun 7, 2010
    Georgia
    Local Time:
    12:54 PM
    No, but then you know how Chrysler was back then. They used everything up they could, so it wouldn't surprise me to see 340 manifolds on somethin they weren't supposed to be on.
  16. Treblig
    5,248
    2255
    Oct 5, 2013
    South Texas
    Local Time:
    11:54 AM
    TRUE!!
    Treblig
  17. Chuckles1980
    Chuckles1980 Member
    14
    3
    Nov 3, 2017
    Marshall
    Local Time:
    12:54 PM
    The new for 1974 "E58" 360 engine produced 245 bhp (183 kW) by utilizing the camshaft, heads, intake manifold, carburetor, and dual-exhaust set up from the past 340. i got this from engine. Plymouth Duster - Wikipedia
  18. Treblig
    5,248
    2255
    Oct 5, 2013
    South Texas
    Local Time:
    11:54 AM
    It says, "dual-exhaust set up from the past 340 engine"...if I say that I have dual exhaust does that mean I have 340 manifolds???
    treblig
  19. toolmanmike
    toolmanmike FABO Staff Staff Member FABO Gold Member
    37,162
    19391
    Jan 18, 2006
    Iowa
    Local Time:
    11:54 AM
  20. oldkimmer
    10,443
    1290
    Nov 11, 2006
    Local Time:
    11:54 AM
    Trebling, no it does not for 1975. I have seen many LRTs up here, no 340 manifolds. Kim
