[FOR SALE] 1976 Dart Sport Lite
celcius232
Active Member
Montana
Rating - 0%
0   0   0
Resurrected from a back yard in NW Montana after a 20 year slumber, runs and drives and can be driven onto a trailer. New gas tank and fuel pump. Just restored the front grill. Too much rust for me, interior roached, and I found out the K member needs replacing. All Lite parts are present has approx. 125K miles. Do not want to part out. $1500. Located 10 miles south of Helena, MT off I-15.
Celcius232
You need to provide more info and pics if you want to move it fast. Rust areas, engine, interior, any body damage,etc. What is it 6 cyl 8 cyl stick auto?
Most of these were taken in April and May, all the original Lite parts are still on the car including the aluminum bumper supports, hood and trunk with aluminum bracing, the OD trans with aluminum case, aluminum intake manifold, carb, and distributor. IIRC the Lite hood and trunk springs are different due to the lighter weight. The PO did a foam and bondo repair on the rear quarters back in the 90s. There are also some rust in the front floor pans and trunk pan. I will have to take more pics of that in the next couple of days as the car is stored 25 miles away from my house. I found a nice grill off a another dart and I repainted and recently installed it. The original radio is missing.
Still for sale. All the Lite parts are there. I have not been able to find a decent 75 or 76 to put them on.
