[SOLD] 1976 Plymouth Feather Duster $2,800
Mopar Automobiles For Sale
Thread Status:
  1. swifterthanyou
    swifterthanyou Well-Known Member
    502
    4
    Jun 2, 2009
    Orange, MA
    Local Time:
    6:03 AM
    Contact Seller
    I started this project a couple of years ago and now it needs to go, am moving in a few months. Clear title on this car.
    It is a 1976 Feather Duster which means it weighed 500lbs less than a standard Duster of the same year. I do not have the correct hood or front bumper (both aluminum substructure), but do have the original trunk lid and rear bumper (both aluminum substructure). This car was originally a slant six, four speed overdrive manual car, I tossed the slant six in place of a 360 four barrel (comes with the car, see parts description below.
    I have started the metal work by replacing the left side quarter skin and right side quarter patch as seen in the pictures as well as the trunk drops (not in pictures). I it will need both front floor replaced however, I am including two new floors with the sale of this car. It will also need patches in the firewall however, I am including a replacement firewall as well (in pictures).
    I have WAAAAYYYY too many parts to list (see pictures) but will say this, I have enough to build this car back to new.
    Parts will include but not be limited too:
    Drivetrain: 360 4bbl engine with original heads AND big valve (2.02") J heads, four speed aluminum overdrive manual transmission that is original to the car, correct 360 flywheel (external balance, will need to be resurfaced), four speed smaill block v-8 bell housing, original open ratio 8.25" rear as well as new 8.25" surgrip rear with 3.55 gear ratio (media blasted and repainted), new coil, new alternator, new... new... new... new radiator,
    Brakes: new rear drum cylinders, new front disc brake calipers, new master cylinder, new braided stainless steel wrapped flex lines for front and rear, drums and rotors have been turned and painted with high heat disc/drum paint etc...
    Suspension: new rear 5-leaf leaf springs with new urethane bushings (pics, all hangers and ubolts have been media blasted and painted), new urethane bushings in upper control arms (media blasted and painted), lower control arms (media blasted and painted), new inner/outer tie rod ends with new adjustable sleeves, new upper and lower ball joints, new idler arm, new pitman arm, k-frame has been media blasted and painted, new shocks all corners etc...
    Interior: three different front seats (they all go with the car, different year styles), new front and rear seat covers (Black in color, original color was tan but was going to die everything black), I may have a new black four speed carpet as well, replacement dash pad
    Items included but not pictures, front fenders (in good condition), all original grill items in good condition (removed for media blasting and priming), and I'm sure I'm missing a host of parts.
    Sale will also include second hood (pic), four 14" rally rims with good tires (rims and center caps media blasted and painted), gas tank and sending unit are newer as well.
    I way more invested in the parts and the car than I am asking so no low ball offers, don't waste my time. I would recommend that you swing by to look at everything, you will be impressed at how much goes with this car.
  2. Dartn440
    Dartn440 FABO Gold Member FABO Gold Member
    3,500
    1127
    Jun 2, 2013
    Southern Pines, NC
    Local Time:
    6:03 AM
    Location?
  3. Dartsun
    Dartsun Mopar Dude
    2,141
    1927
    Feb 12, 2012
    Springfield Oregon
    Local Time:
    3:03 AM
    Profile says Lothian Maryland. Dustin
  4. swifterthanyou
    502
    4
    Jun 2, 2009
    Orange, MA
    Local Time:
    6:03 AM
    Lothian, md
  5. swifterthanyou
    502
    4
    Jun 2, 2009
    Orange, MA
    Local Time:
    6:03 AM
    Lothian, MD
Thread Status:
