[FOR SALE] 1977 440 - Rebuilt
moper
eastern CT
Freshly rebuilt 1977 440. Warranty block - no stampings on the assembly pad or VIN pad. Was truck engine. Block and heads suffered from what I'd call excessive rust in the jackets but they have been cleaned and block run through airless shot to clean it out completely.
Specs: .030 Over, SP forged "six pac" pistons, LY rods redone w/ARP bolts, cast crank turned .010/.010, internally balanced to +/- .1 gram, moly rings. Oil system modifications done, new cam bearings, brass core plugs, oil pump drive w/hardened tip. Heads are 452 truck castings with good guides, new stock type 2.08 intake valves, new 1.74 stainless performance exh valves, viton positive seals, Comp 926-16 springs, with matching retainers and locks. Heads are lightly (Stage 1) ported and gasket matched. Comp 260H hydraulic cam 260/260, .440/.440, 212*@.050. MP timing set, Melling std pump with MP higher pressure relief spring, pickup, "402" pan and factory windage tray, Edelbrock CH4B intake (Chrysler p/n 2836150). New water pump, fuel pump, distributor, wires, temp and oil pressure senders. Comes with complete assembly sheet.
Currently dressed with 68-69 valve covers and water pump housing, and factory forged crank dampener.
Engine has been run and cam broken in on my run stand. With 4150 750cfm Holley it idles at 800rpm, 40psi, 17" vacuum. I'm estimating power around 425hp and 500+torque. Will paint factory color of your choice. I can configure this engine (valve covers and oil pan) to be correct looking/fitting for E body, A body, or C body for additional cash.
Sold as is, where is. Will not ship but can work with buyer to meet or deliver within 300 miles of 06237. Can provide references, installation services, or any other work if needed.
$6500.00 -
