RAMCTD2003
340dart
As the title says this is a roller only. No engine or transmission.
Full tube chassis car. Will need new chassis certification.
Car is all steel.
Set up for a Small Block Mopar and 727 transmission.
Comes with the front and mid plate. 9” rear with 4.44 gears. Comes with a set of 4.89 gears as well.
Slicks are 31.5 x 12.5w x 15 Hoosiers. Front tires are Moroso.
Front wheels are Mickey Thomspon and the rear wheels are Weld draglites.
AFCO rear coilovers. Spindle mount struts in front. Disc brakes all around.
Comes with wheelie bars, radiator, driveshafts for 904 and 727 transmission, MSD digital 6 box
Holley electric fuel pump, holley fuel pressure regulator, and fuel line.
Needs steering column, brake pedal/master cylinder and gas pedal to finish it.
Asking $6500 OBO. Located in Grand Junction, Colorado .
Car is all steel.
