TA head 69?
1984 dodge rampage. Purchased from the original owner. 135k miles. Barn kept. Used to drive to work and back. Big truck driver. Minnesota truck. Turned his license in. 86 years old. Rust around fender edges. Bottom is actually not to bad. Fuel and return lines look the worst. Parking brake cable is hanging. Runs and drives. Has extra wiring, vacumn line plugs etc you would expect from a DIY truck driver owner mechanic. Overall not in bad shape for a 41 year old northern truck. Had plans for a drag and drive project but going with a longer wheel base wider vehicle. Will answer all questions and take extra pictures. Car is located off hwy 75 exit 224 ellenton fl. 34222.
