1985 dodge 360,727 into 1968 dart
Small Block Mopar Engine
  1. jonnyrose
    jonnyrose Well-Known Member
    82
    14
    Aug 30, 2017
    canada
    Local Time:
    9:22 PM
    howdy my plan is to install the 360 from my 1985 prospector and tranny into my 1968 2dr post dart,car had slant six motor tranny combo,so first i know i need to swap oil pan and pickup tube,are all small blocks the same 273-360 as far as oil pans and pickup tubes,will my 727 go right in?
  2. Darter6
    Darter6 Well-Known Member
    3,751
    869
    Jan 16, 2008
    Nevada
    Local Time:
    9:22 PM
    LA 273 318 340 Pans are the same.360 pans are different.I believe the car oil pickups are the same.Tranny should bolt right in.
  3. 318willrun
    318willrun Stomper 4x4... we kept energizer in business
    7,523
    5408
    Sep 13, 2013
    I'm here
    Local Time:
    11:22 PM
    need adapting motor mounts (or change K-frame), different radiator, and a 360 car oil pan and pick up tube. Your tranny coming from a truck would probably be a 727, so your drive shaft will be too long. Have it shortened, or get a different one.
    • Agree Agree x 1
    • Sedanman
      Sedanman 67-9 Valiant specialist FABO Gold Member
      8,342
      517
      Apr 3, 2009
      chicago Il
      Local Time:
      11:22 PM
      They made 2 different oil pick ups and pans for the 360 cars and not interchangable. I'll get you the info
    • Sedanman
      8,342
      517
      Apr 3, 2009
      chicago Il
      Local Time:
      11:22 PM
      360 car pan (876) has a different offset stock center sump pick up than the 392 pan. The 876 sump is only 2" from the front of the pan and the 392 is 4" back. The 876 pan requires the 72-S4 pick up which was special order. The standard pick up is the 72-S2 for the pans with the sump 4" from the front. The 876 is only 2" from the front.
      • Thanks! Thanks! x 1
      • Darter6
        3,751
        869
        Jan 16, 2008
        Nevada
        Local Time:
        9:22 PM
        Cool, Learn something new every day around here !
      • memike
        memike Super Moderator Staff Member FABO Gold Member
        48,869
        8897
        Jan 8, 2006
        on the hill
        Local Time:
        11:22 PM
        I need to remember this @Sedanman , thank you
      • jonnyrose
        82
        14
        Aug 30, 2017
        canada
        Local Time:
        9:22 PM
        this is great,i almost bought the wrong pan.
      • Sedanman
        8,342
        517
        Apr 3, 2009
        chicago Il
        Local Time:
        11:22 PM
        I found out the hard way and tried to use the wrong pick up with the pan I had and had to special order it. Those are Melling part #'s
