It will work perfect! The 727 will require a shorter drive shaft assuming you have the 904. Also, the exhaust manifolds on the 360 will need to be replaced with A-body manifolds or headers. Last, if your duster is a slant six, you'll need the v8 conversion mounts and radiator.
