[SOLD] 1987 Dodge Ram D-350 1-ton rollback roll back
bbrroowwnn
never re member
Drums, PA
I have for sale a 1987 Dodge Ram D-350 1 ton rollback....It has a 318 and a 727 automatic transmission...both have been rebuilt and run good.....It runs and drives great....Inspected until 2017.....PTO and hydraulics work great...ramsey wench that also works great....It has a 17 ft aluminum Chevron bed on it which is also in great shape.....It has 6 brand new tires on it with less than 50 miles on them...new grill...new valve cover gaskets.....body and body mounts are solid......It does need frame repair work though....I have parts to fix frame...Just do not have the time right now to fix it.....asking 4000.00....
Location?
Explain 1 ton.
You're limited to hauling a Smart car ?
Explain 1 ton.
no that is the designation of the truck....150/1500/ are called 1/2 ton......250/2500 are called 3/4 ton..... 350/3500 are dual wheel rear axle and generally referred to as 1 ton......The GVW is 10500
I may be......
From the western part of the state.
This is the worst spot....have to grind off front spring mount, connect two full length existing plates and weld on new spring mount....I have 2 new mounts and new bushings which go with the truck......The other side frame rail front spring mount is OK but I was going to that one too while doing it....
Does it have a rear wheel lift?
It does, but I never used it and don't think it works.....It currently has a tow ball in it for towing a trailer......I bought it like that.......I only have used the flatbed part since I have owned it
