1989 318 Roller Cam Needed
JW MOPAR
Chino Valley, AZ
Hey guys I am very frustrated with this issue and it's the only thing left to do in order for me to assemble my 318. I went to Hughes for a suggested cam and they did just that, suggested. It was late September and I ordered one from Hughes. Didn't hear from them and after 3 weeks I reached out to them. They received my order but stated that it was back ordered and had no idea when one would be available. I stuck with them up until this week and finally canceled my order. Now I am trying to find another mildly upgraded street cam but am totally confused. As stated before it is a 1989 318 with with 302 heads. It has roller lifters and has a long snout. I am not going with the electronic ignition, carbureted. I will also run with an electric fuel pump. I don't want to change valve springs or push rods. I see some available at Summit and Speedway but very confusing as to whether or not they require valve springs, rods or whether they have a long or short snout. I would really appreciate any help you guys can give me. Thank you!
What gears and transmission do you have?
In stock.
That's the biggest problem.....no cores.
CE6P 220/225 DUR@.050, 485/500, 112LC, 1000-6000 33851
If you call...itll go straight to Reuben, Ruebens cams
As a core, would it help to have a cam from an ‘89 360 roller motor? I have one I’m not using, but do cam grinders want these?
Called them, they couldn't help me. My existing cam is too pitted and they didn't have anything else available. Thank you for your reply!
You could start a wanted thread. There's a chance someone here has a stock cam (core) or a mild performance cam they would sell.
