moturbopar
Hi all, I have a set of NEW 2.02 1.62 EQ magnum heads that I'm wanting to sell. The heads are nicely setup. 2.02 + .100 intake valves. 1.623 + .100 exhaust valves. Has bronze liners, No porting . Come assembled with single springs, chromoly retainers. hd keepers. Installed height of 1.73, retainer to seal clearance is .825" were setup to run up to .600" lift
Magnum intake pattern
Comes with crane rocker stud kit.
$1200
check Hughes for price comparison!
You must pay shipping on heads, and they are heavy or local pickup.
Will sell cam and heads for $1400
Also have a nice new solid lifter lunati voodoo cam. http://www.lunatipower.com/Product.aspx?id=5276&gid=342 But with the correct lifters for oiling through push rod, for magnum heads. $240
$1200
