2 bbl. Intake .from a b bodie fit a 318
Gordon Selbig
Corunna mi
I put a 2 barrel intake from a 70 satellite on my 318 barracuda..Now having trouble routing accelerator cable.I have a 273 engine with a low mounting boss.It looks like one off of a valliant. .Will I have to change this to fit my 67 barracuda?
I believe the intakes were all the same from their engine size with the 273 sharing 318 duty until 69. The 70 318 may have been a dual plane so it would have been higher.
I would use the throttle bracket from the 67, it should work.
The cable is tight,
Alan
picture is clear and says a thousand words.thanks. Now I have figure out if I have the correct drivers side exhaust manifold. The battery cable is very close
There is a chance you have your battery cable routed the wrong way, it should follow the harness to the firewall where it drops through a clip and under the column, no where near the exhaust manifold. (At least it does on the 67)
Alan
