Icetech
I posted this over on FBBO but thought i would try here also to get any ideas..
K.. my car is a 62 plymouth, converted from drum to disc over 2 years ago, have never had good brakes, by not good i mean barely slow down.
Here is the system layout..
7/8 Master cylinder (new this week)
all new lines (2 years ago)
everything new actually... kit was from pirate jacks..
Brass distro block with a wilwood prop valve on the rear line.
Pedal ratio is 7:1 with the pivot moved forward to stop it from going overcenter (trick we used on ffr cobras with manual brakes)
DOT5 Fluid.. (i have never used dot 5 but plenty of people have, i can't see it being the issue but never know)
So in the 2 years i have replaced the entire front system twice now other than lines.. 4 master cylinders (smaller sizes til the 7/8) 2 sets of rotors, 2 sets of calipers. 2 sets of pads, now using EBC yellowstuff
I eventually got a pressure gauge to try to track down the issue, with the 7/8MC i get 1000psi at the MC and 1200 if i really stomp it.. i get 1000psi at the connector where the flex line meets the hard line.
At the caliper i get 550-600 tops..
The brakes feel like the pads just won't grab the rotors which i am assuming is from the lower pressure, if not then i am really confused.. Rotors are brand new bendix as of a week ago, calipers are new also as of a week ago.
So.. the only thing between the 1000psi and 550psi is the flex line and caliper, and before someone asks.. not the caliper isn't upside down
I have bled them many times, zero air, nice stiff pedal..
Right now i even plugged the passenger front port at the distro block to isolate the drivers side to try to find my pressure issue one just one before i re-add the other.
Soo.. i know flex lines can swell and make it so calipers won't retract, no issue with that here..
I get plenty of fluid out when when bleeding..
so i'm just hoping someone may have had an issue like this before or have an idea, parts canon hasn't worked. I'm to the point of looking for a set of drums to put back on just so i can drive it safely.
P.S. i have done brakes for 40 years and never ran into anything like this...
Gonna add a couple of vids showing the pressures.. the videos are me pushing at 3 different levels, normal braking, harder and very hard..
BTW.. the distro block one has about 3" of air in the line for the gauge and did 1000psi... caliper has zero air.
At Caliper
At distro block
At Caliper
At distro block
