2 years chasing low pressure at the caliper...
Not a lot to that.
yeah, it's just a junction to the rears and a T for the front... very caveman..
I mean.. this system should be soooo idiot proof and i am too much of an idiot :)
Have you tried watching the caliper piston move without a rotor installed?
No.. but 2 sets of calipers.. and they do move, they just don't bite.. 550psi isn't enough for discs at all...
Was just thinking that it would be hilarious if it's the banjo bolts
Refresh me- happening on both sides?
Dang sure could be.
Some have to be lined up, right?
I think I remember once something was covering the hole in the bolt.
Don't remember what it was.
Moved it, and it worked.
I do have 2 different length banjo bolts though like 1/8" difference and both did the same
I mean extra washers installed that could alter the position of the banjo bolt/banjo hole.
I just did a cursory search on banjos-
Looks like some call for two washers.
if it's not spaced right, the hole can be blocked or partially blocked.
2 under and 1 on top? interesting, i have never heard of that but will try anything :)
The pics showed two on the bolt head side.
Look at it carefully and maybe even measure/stack up the bolt and washer(s) beside the banjo fitting.
make sure A- the washer doesn't cover the hole and B- the washer doesn't move the hole down so the fitting covers the hole.
It's like 1-3/32 inch clearance and a 1/32" hole, right?
That's tight.
...and a 1/32" washer...
That's tight.
yeah, pretty small... i hadn't even thought of that, you would think the **** would just be a standard
I'm guessing on the bottom.
wheres the 5th port?
2 + 3 =5
the 2 on the top are in, there is one on the back that goes to the rear brakes, one out the front goes to the left front and one on the side you can't see in the pic goes to the right front
