2 years on coolant and about 750 miles on it.
Heating / Cooling / AC
  1. TRWRacing
    TRWRacing Well-Known Member
    379
    58
    Nov 3, 2015
    Chicago
    Local Time:
    9:38 AM
    Green conventional antifreeze 50/50 mix in Chicagoland. Can I wait another year or change it before winter storage this year? 360 LA with new radiator and heater core 2 years ago.
  2. famous bob
    famous bob mopar misfit
    19,552
    8605
    Aug 14, 2011
    okla
    Local Time:
    9:38 AM
    I wouldnt worry about it , just make sure it good for ur areas temps---------------
    • Agree Agree x 3
    • 318willrun
      318willrun Utube channel 318willrun
      16,987
      19043
      Sep 13, 2013
      I'm here
      Local Time:
      9:38 AM
      your fine.... make sure it's good for at least 25 below
      • Agree Agree x 1
      • toolmanmike
        toolmanmike FABO MODERATOR Staff Member FABO Gold Member
        58,706
        46119
        Jan 18, 2006
        Iowa
        Local Time:
        9:38 AM
        It should be fine.
      • inertia
        inertia Well-Known Member
        3,467
        739
        Feb 4, 2011
        Victoria B.C. Canada
        Local Time:
        7:38 AM
        If it's clean and green, pH close to 7, good to go.
        If pH is way off, adjust to prevent electrolysis .
        • Agree Agree x 2
        • Like Like x 1
        • Dana67Dart
          Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
          6,346
          4163
          Jul 16, 2017
          Northern Colorado
          Local Time:
          8:38 AM
        • 67Dart273
          67Dart273 FABO Gold Member FABO Gold Member
          48,292
          16328
          Oct 14, 2010
          Idaho
          Local Time:
          7:38 AM
          Run purified/ distilled water, add some inhibitor once in awhile and run it. "In reality" you should do chemical checks for balance and adjust. DO NOT RUN tap water
          • Agree Agree x 1
          • flingdingo
            flingdingo Well-Known Member
            332
            263
            Apr 26, 2017
            El Lay
            Local Time:
            7:38 AM
            Dump it. Coolant breaks down over time and forms acids which attack the various metals in your cooling system.
            $15 for a gallon of antifreeze every other year is cheap insurance IMO.
            • Agree Agree x 3
            • TRWRacing
              379
              58
              Nov 3, 2015
              Chicago
              Local Time:
              9:38 AM
              Tested good to -34* 50/50 mix and a ph level of 9
            • Dana67Dart
              6,346
              4163
              Jul 16, 2017
              Northern Colorado
              Local Time:
              8:38 AM
              Looks like your fluid is about as basic as baking soda. Don't know if the is good or bad!
            • 67Dart273
              48,292
              16328
              Oct 14, 2010
              Idaho
              Local Time:
              7:38 AM
              Horse shit. As I said run purified water, add some chemical stabilizer/ inhibiter if needed.
            • Mattax
              Mattax Just the facts, ma'am FABO Gold Member
              11,910
              7644
              Feb 7, 2013
              Phila. Pa
              Local Time:
              10:38 AM
            • Mike69cuda
              Mike69cuda 66 is the new 17 FABO Gold Member
              2,279
              1797
              Jan 2, 2018
              Overland Park Kansas
              Local Time:
              9:38 AM
              My cars have always had an automatic maintenance feature. When ever a hose breaks, I change the antifreeze.
              • Like Like x 6
              • Thanks! Thanks! x 1
              • flingdingo
                332
                263
                Apr 26, 2017
                El Lay
                Local Time:
                7:38 AM
                Whaddaya think they put in the coolant? That shit breaks down too.
              • MoparLeo
                MoparLeo NRA PATRON LEVEL LIFE MEMBER FABO Gold Member
                700
                448
                Feb 10, 2016
                Moreno Valley, Cal. So. Cal.
                Local Time:
                7:38 AM
                Refractometer is the tool you need.The cost of fluid replacement versus the cost of any possible cooling system damage should make it a no brainer.
                • Agree Agree x 1
                • RustyRatRod
                  RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                  71,748
                  46935
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  10:38 AM
                  Oils and fluids have come a long way in a short time. They have way more modern additive packages in them than they once did. If you run distilled water (like you're supposed to anyway) coolant will last a really long time.
                  • Agree Agree x 2
                  • Dana67Dart
                    6,346
                    4163
                    Jul 16, 2017
                    Northern Colorado
                    Local Time:
                    8:38 AM
                    Question...
                    How often do you change your coolant in your modern cars, have you ever changed your coolant? 5 years, 10 years, never?
                    Interestingly the FSM says to "drain, flush, and refill the cooling system once a year... "
                  • RustyRatRod
                    71,748
                    46935
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    10:38 AM
                    Kitty's car is a 2004 Ford Escape. We bought it new in December of 2003. Were it not for the fact we've hit two deers in it during the time we've owned it and it got the radiator both times, it'd still have the original Ford gold coolant in it. The first deer hit I would "guess" was about 2013. When I replaced the radiator then, the first time, the coolant still looked "new".
                  • pishta
                    pishta I know I'm right....
                    19,835
                    9205
                    Oct 13, 2004
                    Tustin, CA
                    Local Time:
                    7:38 AM
                    Premixed coolant uses distilled water, no need to add anything. Always thought that was a lazy 100% markup but when distilled water is .89 a gallon at Walmart, it makes sense to buy straight coolant and a jug or 2 of distilled water at the same time. Save your old empty jugs and premix in there. 2 for 1! I doubt the new stuff breaks down in under 5 years or 150k myself. 5 year Dexcool is class action lawsuit SHIT, but the newer OAT/HOAT stuff is way better. Use the green for brass radiators and heater cores. The OA is for Organic Acid, and that does break down over time.
                    • Like Like x 2
                    • Agree Agree x 1
                    • Mattax
                      11,910
                      7644
                      Feb 7, 2013
                      Phila. Pa
                      Local Time:
                      10:38 AM
                      AFAIK every major manufacturer since the mid-2000s has gone to a cooling system that completely keeps the air out. That is a critical for the newer organic acid coolants to be effective. It takes time for OAT & hybrid OAT coolants to build up its protective character in an engine and radiator. Once it does it can last a relatively long time compared to conventional IAT antifreeze. But since our systems are semi-open, the fast acting characteristics of conventional is the best match.
                      http://www.pqiamerica.com/Antifreeze_Coolant_Timeline.pdf
                      Coolant Confusion: It's Not Easy Being Green ... or Yellow or Orange or ... | MOTOR
                      • Agree Agree x 1
                      • ir3333
                        ir3333 Well-Known Member
                        4,850
                        1377
                        Jun 1, 2008
                        ontario,canada
                        Local Time:
                        9:38 AM
                        I'll bet 99% of personal autos never get their coolant changed for years!
                        • Agree Agree x 2
                        • MoparLeo
                          700
                          448
                          Feb 10, 2016
                          Local Time:
                          7:38 AM
                          Just an FYI. Cooling system failures are and have been the number one cause of auto breakdowns in the US for many years.
                          • Like Like x 1
                          • Mike69cuda
                            2,279
                            1797
                            Jan 2, 2018
                            Local Time:
                            9:38 AM
                            I thought General Motors was the number one cause of auto breakdowns....
                            • Like Like x 2
                            • Agree Agree x 1
                            • sireland67
                              sireland67 FABO Gold Member FABO Gold Member
                              9,593
                              3843
                              Oct 27, 2010
                              WV
                              Local Time:
                              10:38 AM
                              1:1 if you live where it freezes.
                            • Mattax
                              11,910
                              7644
                              Feb 7, 2013
                              Phila. Pa
                              Local Time:
                              10:38 AM
