I'm putting a brake controller in temporarily to pull a 16 foot two axle trailer that I intend to transport a commercial 4 post lift on (2900 pounds).
I've got it working manually, but I'm having trouble finding a definitive answer on which wire from the brake light switch to use for the trigger.
There are several wires in the connector (about 8 IIRC).
It looks like a PITA to use a meter to find the right one because the wires are thin, and packed tight in the connector.
One source said white with either red or brown tracer but now I can't find that page and none of the other hits has that info.
Anyone hook up a controller in a 2000-ish Dak and can verify?
