1. Cope
    Cope Fusing with fire
    2,820
    2513
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    3:55 PM
    I friend is looking at buying one with the 5.7 and was asking if I knew anything about them. I said no but I'll ask.
    So what do you folks know, they got any problems he should be aware of?
    Thanks for the advice.
  2. Hellrats
    Hellrats Still wrenching after all these years FABO Gold Member
    907
    644
    Jan 24, 2012
    N.E. Ohio
    Local Time:
    4:55 PM
    Tension struts and upper ball joints mostly on the early ones. If you need upper ball joints you have to replace both upper control arms as a pair because they took some caster out of them. Call a dealer and have them run the VIN. There is a recall on the air bags. Also some of them had a timing chain recall. Other than that not bad cars.
    • Thanks! Thanks! x 1
    • Tooljunkie
      Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
      8,609
      7122
      Jul 22, 2017
      Manitoba
      Local Time:
      3:55 PM
      Awd go like hell!
      Road tested one, in winter with high end snow tires. Was like it was on rails.
      • Agree Agree x 1
      • Hellrats
        907
        644
        Jan 24, 2012
        N.E. Ohio
        Local Time:
        4:55 PM
        Oh yea the tension strut and upper ball joint problem was only on the rear wheel drive cars. Completely different set up on the AWD front ends.
      • diymirage
        diymirage HP@idle > hondaHP@redline
        14,949
        7330
        Oct 12, 2012
        michigan
        Local Time:
        4:55 PM
        no kidding, my "winter beater" is an 08 AWD charger (basically the same car)
        only managed to get it stuck once, in 10 michigan winters, and that time i went so high up a snow bank all 4 of my tires were off the ground
        and only thing that wasnt a wear item i replaced on that car, in 160K miles were a set of CV boots
        i didnt know the AWD came with the 5.7 though?
        • Like Like x 1
        • rumblefish360
          rumblefish360 so close yet so far away
          34,092
          6015
          Jun 21, 2005
          New York, on a Island
          Local Time:
          4:55 PM
          Now that is awesome. That’s when my wife says I was having to much fun.
          I think only the V6 came with AWD.
          It is that way with the Challenger.
        • Hellrats
          907
          644
          Jan 24, 2012
          N.E. Ohio
          Local Time:
          4:55 PM
          I believe 2015 was the last year you could get the AWD with a 5.7
        • Hellrats
          907
          644
          Jan 24, 2012
          N.E. Ohio
          Local Time:
          4:55 PM
          They never made an AWD Challenger. Maybe your thinking the Charger.
        • rumblefish360
          34,092
          6015
          Jun 21, 2005
          Local Time:
          4:55 PM
          There is a AWD Challenger currently offered by Dodge.
        • lilfontleroy
          lilfontleroy annoyinglilLeRoy FABO Gold Member
          945
          731
          Nov 20, 2017
          USA
          Local Time:
          3:55 PM
          5 Things to Know About the 2018 Dodge Challenger GT AWD
          git you summa-dat!!!
        • Hellrats
          907
          644
          Jan 24, 2012
          N.E. Ohio
          Local Time:
          4:55 PM
          Sorry, I thought you were talking about 2005-2011
        • rumblefish360
          34,092
          6015
          Jun 21, 2005
          Local Time:
          4:55 PM
          No AWD back then. It’s a decent addition the AWD.
        • lilfontleroy
          945
          731
          Nov 20, 2017
          USA
          Local Time:
          3:55 PM
          if it has tires or t*ts... I have heard the 5.7 has more aftermarket performance support then the 6.4 and has a stronger bottom end
        • Cope
          2,820
          2513
          Oct 20, 2009
          San Jose, Ca.
          Local Time:
          3:55 PM
          How does one go about checking the car for a recall? Can he just call a dealer with the VIN?
          • Like Like x 1
          • Hellrats
            907
            644
            Jan 24, 2012
            N.E. Ohio
            Local Time:
            4:55 PM
            Yes just call any Chrysler dealer ship and give them the VIN. They can run it while your on the phone and tell you if there are any open recalls.
            • Hellrats
              907
              644
              Jan 24, 2012
              N.E. Ohio
              Local Time:
              4:55 PM
              Yes there may be more bolt on parts in the aftermarket for the 5.7 but the 6.4 is no baby. There are just less of them so there is less of a market for the parts. None of them have a stronger bottom end than the other.
              • Like Like x 1
              • diymirage
                14,949
                7330
                Oct 12, 2012
                michigan
                Local Time:
                4:55 PM
                Maybe the 5.7 needs more support to run decent ?
              • 68cuda408
                68cuda408 FABO Gold Member FABO Gold Member
                422
                111
                Jun 4, 2013
                11967 NY
                Local Time:
                4:55 PM
                I just bought a 2011 hemi awd 300c to split mileage on my truck .I don't think anyone mentioned that the 11 is a different car than 05-10 and the awd system is different (supposedly better integration).You cannot disable the awd even with the esp button off. Unlike the older cars it runs rwd only and awd on torque demand. If you shut off the traction control it locks awd on. The car is a 4300# leather filled rocket.
                • Like Like x 2
                • lilfontleroy
                  945
                  731
                  Nov 20, 2017
                  USA
                  Local Time:
                  3:55 PM
                  I couldn't begin to guess - there is no replacement for displacement
