2010 5.7 Hemi into 1971 Demon
New Hemi Engine Swaps
  1. champyfz450
    champyfz450 Well-Known Member
    59
    24
    Sep 14, 2013
    Alberta
    Local Time:
    3:44 PM
    I've spent many hours reading the threads on this website, but I figured it best to start a new thread of my own to address any particular issues that I may have. Please let me know if any of you knowledgeable folks see any flaws in my plan.
    Heres what I have:
    1971 Dodge Demon (318/904)
    2010 eagle 5.7 truck engine (No cam or lifters as it wiped a cam lobe)
    2006 truck harness (plan to pinout the harness for my needs)
    2006 computer (I know 05 is preferred, can the 06 be used?)
    Heres what I need:
    MDS elimination kit MPR53032221AA (shophemi.com)
    Oil filter relocate MPR53021610AF (shophemi.com)
    TTI headers TTI61HC-c4 (TTIexhaust.com)
    TTI motor mounts 57MMA (TTIexhaust.com)
    Comp XFI273 Cam 249-112-501-11 (Jegs)
    Comp non MDS lifters w/eliminator kit 312-53032221AAK (Jegs)
    Milodon oil pan MIL-31000 (modernmuscleextreme)
    Milodon centre sump pickup MIL-18331
    Napa coolant Hoses NAPA9128 (upper) NAPA7515 (lower)
    Cam Phaser lockout kit CMP-5760 (shophemi.com)
    If there is anything that I am missing or if you have any questions please feel free to post it up.
    • Like Like x 3
    • Johnny Mac
      Johnny Mac www.blueprintengines.com FABO Vendor
      3,800
      3007
      Jul 10, 2010
      OHIO
      Local Time:
      4:44 PM
      You are mixing two very different animals.
      That cam wont go in the vvt engine. Reluctors are different also, so computer isnt correct.... gonna take some research.
      • Thanks! Thanks! x 1
      • champyfz450
        59
        24
        Sep 14, 2013
        Alberta
        Local Time:
        3:44 PM
        Thank you Johnny. I'll look into it.
      • Johnny Mac
        3,800
        3007
        Jul 10, 2010
        OHIO
        Local Time:
        4:44 PM
        You can put an old reluctor into the new engine, but you also need a custom timing set that would allow the old computer to be used.
        IMO, You are honestly better off abandoning the harness and ecu you have, and getting an aftermarket harness/ecu for the vvt engine. Put a vvt era cam in it, even with a vvt limiter or lock.
        Vvt era oil pickup is also diff than pre 09
        • Agree Agree x 2
        • champyfz450
          59
          24
          Sep 14, 2013
          Alberta
          Local Time:
          3:44 PM
          Thank you very much for the clarification Johnny. I have considered hotwire and Megasquirt so at some point today I will make a decision on which to use and order it up.
          Also, I lookes at a VVT compatible cam through modernmuscleextreme, are those suckers ever expensive!!! ouch!
          • Agree Agree x 1
          • 408 swinger
            408 swinger FABO Gold Member FABO Gold Member
            2,323
            2161
            Nov 12, 2010
            Iowa
            Local Time:
            3:44 PM
            Best bang for the buck, 6.4 SRT auto cam. It's like 70 bucks from Mopar. I've done a couple of 5.7 VVT engines with this cam. Wakes it up! Also have used the Hotwireauto harness and computer. Easy-to-use and can keep the vvt, and, delete the MDS.
            • Like Like x 1
            • champyfz450
              59
              24
              Sep 14, 2013
              Alberta
              Local Time:
              3:44 PM
              Thank you very much for that! I was researching vvt performance cams and was horrified by the price.
              So would I just pair that cam with a set of non mds lifters (since I want that removed) and use the mds eliminator kit for the plugs on top of the block?
            • 408 swinger
              2,323
              2161
              Nov 12, 2010
              Iowa
              Local Time:
              3:44 PM
              Yep! Make sure you use Non-MDS yokes, too. The lifter bodies on the MDS are a little bigger. If you put a Non-MDS lifter in a MDS yoke, it is too sloppy. Allows the lifter to rotate slightly.
              • champyfz450
                59
                24
                Sep 14, 2013
                Alberta
                Local Time:
                3:44 PM
                So essentially I should be looking for lifter yokes from an earlier engine, that didnt come with MDS?
                • Agree Agree x 1
                • Cudazilla
                  Cudazilla Member
                  18
                  9
                  May 8, 2019
                  Valley Springs, California
                  Local Time:
                  1:44 PM
                  I believe if you go with the 6.4 cam, you also need different springs and pushrods due to the lift. Also I would go with hellcat lifters as they are pretty beefy compared to stock older versions. Maybe someone can correct me if I'm wrong but I read somewhere that dodge used msd lifters in older engines but were never activated. I haven't tore into a older block to see the lifters myself to verify this but something I read somewhere.
                • Cudazilla
                  Cudazilla Member
                  18
                  9
                  May 8, 2019
                  Local Time:
                  1:44 PM
                  Well I corrected myself, here is a add for stock oem non msd lifters with years and applications, if that helps
                  • Agree Agree x 1
                  • champyfz450
                    59
                    24
                    Sep 14, 2013
                    Alberta
                    Local Time:
                    3:44 PM
                    Thank you very much for that cudazilla there’s a lot of good technical info in that ad! Appreciate it.
                  • Cudazilla
                    Cudazilla Member
                    18
                    9
                    May 8, 2019
                    Local Time:
                    1:44 PM
                    No problem, good luck!
                  • champyfz450
                    59
                    24
                    Sep 14, 2013
                    Alberta
                    Local Time:
                    3:44 PM
                    So to clarify, I will now be using the 6.4 cam with mopar non mds lifters. What about pushrods guys, will I use the early non MDS engine pushrods and valve springs?
                  • 408 swinger
                    2,323
                    2161
                    Nov 12, 2010
                    Iowa
                    Local Time:
                    3:44 PM
                    I have put the 6.4 cam in the Eagle engines. Left the 5.7 springs and pushrods. No issues.
