2012 truck engine in a duster
Discussion in 'New Hemi Engine Swaps' started by Edsrt, Mar 10, 2018.
  1. Edsrt
    Edsrt Active Member
    37
    9
    Mar 6, 2018
    Washington nj
    Local Time:
    12:51 AM
    I am new to this forum but had A bodies all my life.i recently acquired a 2012 ram 5.7 complete with engine harness, no pcm.i would like to put it in my 1970 duster 4spd,Bolting the engine in the car seems easy enough ie mounts , exhaust and mds delete . I would like to use the factory fuel injection and possibly the vvt system . Called mopar performance about using their crate motor installation kit and was told it will not work on this year engine. Has anyone use the mopar kit on engine other than their crate motor
  2. JDMopar
    JDMopar Well-Known Member
    1,542
    416
    Jan 19, 2012
    Candler, NC/Myrtle Beach, SC
    Local Time:
    12:51 AM
  3. Edsrt
    Edsrt Active Member
    37
    9
    Mar 6, 2018
    Washington nj
    Local Time:
    12:51 AM
    Thanks I was looking at them and also megasquirt and the Mopar kit seemed be the best fit, because I could not see much difference between controlling a challenger 5.7 and a truck 5.7
  4. JDMopar
    1,542
    416
    Jan 19, 2012
    Local Time:
    12:51 AM
    One more place that I forgot about, that I may very well use myself! Good prices, and they seem to know their stuff.
    Products – Swap Specialties
  5. KosmicKuda
    KosmicKuda Well-Known Member
    1,329
    239
    Jan 15, 2011
    N Ohio
    Local Time:
    12:51 AM
    [QUOTE="Edsrt, post: 1972012538, member: 52986 I Called mopar performance about using their crate motor installation kit and was told it will not work on this year engine. Has anyone use the mopar kit on engine other than their crate motor[/QUOTE]
    I believe somewhere in the "new" Mopar harness documentation it states it is for 2014 and newer engines.
  6. Edsrt
    Edsrt Active Member
    37
    9
    Mar 6, 2018
    Washington nj
    Local Time:
    12:51 AM
    I believe somewhere in the "new" Mopar harness documentation it states it is for 2014 and newer engines.[/QUOTE]
    Thanks I I was trying to figure out what the difference between a 2012 and a 2014 because I thought they changed in 2015 em wise
